Transformerless line powered digital AC voltmeter
ihsanbu
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Sun Aug 14, 2011 3:26 pm     Reply with quote
Hi all
I require coding help by designing the AC voltmeter using US patent
http://www.freepatentsonline.com/4908569.html
I am using the pic18f452 adc channel 0.
The input voltage range to measure the circuits in this patent are from 100vac to 500VAC and patents circuits will give voltage from 0vdc to 5vdc.
1- I require that the value measured the circuits from 0-->5vdc must be displayed on lcd/serial in form on like 220vac if the micro controller measured 3volt via adc and so on.
2- AC line power based threshold measurement and bit on/off
if input voltage is >250 the PORT C.0 become low other high.
The complete picture is here
http://imageshack.us/photo/my-images/233/acvoltmeterandpic18f452.jpg/
http://imageshack.us/photo/my-images/830/acvoltmeterandpic18f452.jpg/
regard
Thanks in advance
PostPosted: Mon Aug 15, 2011 5:11 am     Reply with quote
First be very,very careful with 'transformerless' circuits as they can EASILY KILL YOU !!! Do yourself a big favour and build using batteries or a wallwart powersupply. Once you've got the code working, THEN rewire for LIVE LINE operation.NOTHING ruins your day than to get 'zapped'.Chips are cheap, your life isn't.
that being said , there are hundreds of 'digital voltmeter projects with code on the Web just let Google help you.
once you have your code cut, send it here and we can help you 'tweak' it.
asmallri
Re: Transformerless line powered digital AC voltmeter
PostPosted: Mon Aug 15, 2011 7:51 am     Reply with quote
ihsanbu wrote:
Hi all
regard
Thanks in advance
The US patent system really is rubbish. How anybody can get a patent for this is beyond me. No new technology. I did this 25 years ago.
Regards, Andrew
FvM
PostPosted: Mon Aug 15, 2011 8:17 am     Reply with quote
My impression, too.
If you want to retrieve the documents, you also can enter the patent number at the EPA server patent search
http://worldwide.espacenet.com/?locale=en_EP
newguy
They'll grant a patent for anything it seems, but whether it stands up in court is another matter... Wink
SherpaDoug
PostPosted: Mon Aug 15, 2011 8:34 am     Reply with quote
If not for the high voltage this would be a high school science project.
[Gripe]Many times I have drawn up a design from scratch only to be told by my boss that someone has patented it and to find another way. There is never even a consideration of paying the inventor for a license.
Yes the patent system is broken and only serves to feed lawers and suppress invention. [/Gripe]
PostPosted: Mon Aug 15, 2011 1:07 pm     Reply with quote
patent -smatent
this particular patent is soooo
EASY TO WORK AROUND - not to mention obvious -
-I HAVE TO WONDER WHY
anybody would bother to pay tribute at all.
( no matter what level of production the end result might achieve )
