Problem reading parallel inputs in
Maqhawe
PostPosted: Mon Aug 08, 2011 4:14 am     Reply with quote
Hi there
I am fairly new to C programming and I need help in designing a program that will read 4 parallel inputs and ensure that they are incrementing sequentially. That is from 0000 to 1111.
If I may add, I am trying to test the functionality of a 4-bit absolute encoder. So my plan is to design a sequential test using a PIC18F4525 to achieve this.
SherpaDoug
PostPosted: Mon Aug 08, 2011 2:22 pm     Reply with quote
Do you have any sort of strobe signal that tells you the pins have changed? If not you just have to keep reading and subtract the "old" value. If the result is 0 nothing has changed. If the result is 1 then they have incremented and you have a new "old" value. If the result is anything else you have an error, though if it is 2 or 3 you may have just missed a count or two.
Maqhawe
PostPosted: Tue Aug 16, 2011 8:48 am     Reply with quote
thanks SherpaDoug
I have taken your advice into consideration and now Implementing it in code
