Ringo42
how to use streams |
Posted: Fri Jul 15, 2011 1:23 pm |
I'm missing something with the streams parameter in use232
This works
Code: | #include <18F2221.h>
#fuses HS,NOWDT,NOLVP
#use rs232(baud=115200, xmit=PIN_c6, rcv=PIN_c7,errors,bits=8,parity=N,)
//#use rs232(baud=115200, xmit=PIN_c6, rcv=PIN_c7,errors,bits=8,parity=N, stream=lidar)
//#use rs232(baud=115200, xmit=PIN_c0, rcv=PIN_c1,errors,bits=8,parity=N, stream=debug)
#include <stdlib.h>
void main ()
{ int i=0;
// printf(lidar,"test %u\r\n",i++);
printf("test %u\r\n",i++);
but this does not
//#use rs232(baud=115200, xmit=PIN_c6, rcv=PIN_c7,errors,bits=8,parity=N,)
#include <stdlib.h>
void main ()
{ int i=0;
// printf("test %u\r\n",i++);
for this simple test shouldn't they work the same? did I miss a step? _________________ Ringo Davis |
Posted: Fri Jul 15, 2011 1:33 pm |
Look in the CCS manual at fprintf, fputc, fgetc, etc. |
Ringo42
Posted: Fri Jul 15, 2011 1:47 pm |
ok I get it, you have to do fprintf when you use a stream.
Next question, I don't see this addressed in the manual. If you have 2 streams defined and one of them uses the Hardware Rx and TX pins. Does int_rda always fire on the stream that uses the hardware pins? I think it does but I want to make sure there is not something else that happens when using streams. _________________ Ringo Davis |
Posted: Fri Jul 15, 2011 1:50 pm |
Code: | Does int_rda always fire on the stream that uses the hardware pins? |
That's correct. #int_rda only works with the hardware UART.
If you want an interrupt on a software UART, you could use pin B0 for the
Rx, and use #int_ext to detect the start of a char and receive it using
fgetc inside the isr. |
exception |
Posted: Thu Jul 21, 2011 3:55 pm |
with the appropriate pic and hardware design -
you can do an #INT mediated RX function
using a B port edge trigger INT and
the matching pin as your soft RX input -
i have code somewhere that shows how
it does have limits however in that
it CAN mess up a synchronous XMIT on the soft uart |
