| View previous topic :: View next topic   |
			cfernandez
				| Eclipse and CCS |
				 Posted: Sun Feb 26, 2006 9:40 am     |
Any use the eclipse enviroment with CCS? |
			jma_1
				 Posted: Mon Mar 06, 2006 12:23 pm     |
				Greetings,
I have not used CCS compiler w/ Eclipse, but I've been toying with the idea myself.  I've used the C/C++ (CDT) package with Eclipse and the MinGw compiler with good success.  If you setup the Make file specs to call the CCS compiler, everything should work.  Getting the debugger to parse the compilation errors might be interesting.  See previous postings for setting up the CCS compiler w/ CodeWright (hints on setting up error parsing).
Please let me know how things work out.
Cheers,
Justin |
			carlosluis
				| Yes is possible CCS and eclipse |
				 Posted: Fri Apr 28, 2006 2:13 pm     |
				You'll have to read a little bit about how to use GNU make which is the one responsable to call the compiler and linker (when there's one). Following is my make file, again you need to have a basic understanding of the makefile syntax:
#RENAME AS NEEDED
#PROJECT=realtek
PROJECT=c-22d
RM := rm -f
MV:= mv -fv
CP:=cp
#The CCS compiler
CC = ccsc
#Misc options
C-COMMON=C:\reddwrks\lights2\c-common
DEVICES=C:\Program Files\Microchip\PICC\Devices
DRIVERS=C:\Program Files\Microchip\PICC\Drivers
C-22D=C:\reddwrks\wrkspace\four
INCLUDES=I="$(C-COMMON);$(DEVICES);$(DRIVERS);$(C-22D)"
BUILD-DIR:=C:/reddwrks/wrkspace/four/build
#+FH= PCH 18 Architecture,+DC Expanded COD file (ICE 2000),+L do not create
#list file, -E list only the first error, +STDOUT redirect to the standard
#output
CFLAGS= +FH +DC +LO -E +A +STDOUT
#Environment variables
PLATFORM=+GFOUR_INCH_DISPLAY="1"
#PLATFORM=+GPROTOBOARD="1"
#PLATFORM=+GELEVEN_INCH_DISPLAY="1"
#Main function location definitions
USER_MAIN="1"
BOOT_MAIN="2"
MAIN_LOC_USER=+GMAIN_LOCATION=$(USER_MAIN)
MAIN_LOC_BOOT=+GMAIN_LOCATION=$(BOOT_MAIN)
COMPILE=$(CC) $(PROJECT).c $(INCLUDES) $(CFLAGS) $(PLATFORM) $(MAIN_LOC_BOOT)
COMPILE-UPGRADE=$(CC) $(PROJECT).c $(INCLUDES) $(CFLAGS) $(PLATFORM) $(MAIN_LOC_USER)
#Known extentions
HEX=HEX
LST=LST
COD=cod
ERR=err
STA=sta
SYM=SYM
PJT=PJT
all: $(PROJECT).$(HEX)
$(PROJECT).$(HEX): $(PROJECT).c
ifeq ($(FIRMWARE_UPGRADE),1)
	@echo Compiling for upgrade image:
	$(COMPILE-UPGRADE)
	@$(MV) $(PROJECT).$(HEX) c-22d-upgrade.$(HEX)
	@echo Compiling for a base image with bootloader:
	$(COMPILE)
endif
	@$(CP) *.$(HEX) 	$(BUILD-DIR)
	@$(MV) *.$(LST)	$(BUILD-DIR)
	@$(MV) *.$(COD)	$(BUILD-DIR)
	@$(MV) *.$(ERR)	$(BUILD-DIR)
	@$(MV) *.$(STA)	$(BUILD-DIR)
	@$(MV) *.$(SYM)	$(BUILD-DIR)
	@$(MV) *.$(PJT)	$(BUILD-DIR)
clean:
	@$(RM) $(BUILD-DIR)/*.$(HEX)
	@$(RM) $(BUILD-DIR)/*.$(MAP)
	@$(RM) $(BUILD-DIR)/*.$(LST)
	@$(RM) $(BUILD-DIR)/*.$(COD)
	@$(RM) $(BUILD-DIR)/*.$(ERR)
	@$(RM) $(BUILD-DIR)/*.$(STA)
	@$(RM) $(BUILD-DIR)/*.$(PJT)
	@$(RM) $(BUILD-DIR)/*.$(SYM)
	@$(RM) *.$(HEX)
	@$(RM) *.$(MAP)
	@$(RM) *.$(LST)
	@$(RM) *.$(COD)
	@$(RM) *.$(ERR)
	@$(RM) *.$(STA)
	@$(RM) *.$(PJT)
	@$(RM) *.$(SYM) _________________ Carlos Luis |
			mds
				 Posted: Wed Jul 13, 2011 10:11 pm     |
				Hey guys this is a pretty old topic. I was just wondering if it had gotten any easier or if anyone had any more thoughts on using Eclipse.
I had to do a Python app a while back and thought it would be a good opp to give eclipse a trial.
Was very happy with the results and soon found myself wishing there was a plugin for CCS.
Don't know much about setting up such things.
Sure its large n bloatware but it sure made my source writing a whole lot easier than the cumbersome and feature poor CCS IDE.
Anyone else using it? |
			Sergeant82d
  Joined: 01 Nov 2009 Posts: 55 Location: Central Oklahoma
				 Posted: Mon Jul 18, 2011 2:54 pm     |
				As far as I've ever been able to find out - with lots of time spent searching online - there is no available plug-in to use CCS with Eclipse.
That said, the new MPLAB X IDE from Microchip is based on NetBeans... and is far more advanced than the current 8 series version. It is capable of anything Eclipse can do, and is far less bloated.
It is still in Beta (ver 6), but is very usable with some learning curve needed.
HTH. |
			mds
				 Posted: Thu Jul 21, 2011 8:48 pm     |
				Hi NTH,
Thanks for your response. I have just spent some time playing with Netbeans from a Python perspective. I dont sue Java and Python is the only other language other than CCS I use nowadays. I was using Eclipse to write this app last week, so it was fresh in my mind. Nb had a few issues with Python or at least my understanding of it and I have raised those on the NB forum. It certainly did not work out of the box like Eclipse did.
Anyway I moved onto mplab X and indeed its very NB like   I ran into problems fairly early on tho.
I could not work out how to add the ICD-U64 programmer that we are using (CCSload) into the tools on a new project.
Im also having problems with pathing. #include <stdlib.h> for example is in error with cant be found.
Spellchecking not working on comments
bookmarks arnt much better than CCS
at least it has Tasks ...if I cant get them to work
and supports SVN
However its looking promising
learning curve   |
