		| Author | Message |
		| CCS newby
				| Printf not printing floating point numbers correctly. |
				|  Posted: Fri May 27, 2011 7:54 am |   |
				| I am using printf in a function off main to printf a floating point variable.  This does not work work correctly and always prints the variable as 0.00.  If I insert a line into the main function to printf a floating point variable this then works and also makes the printf in the other function work correctly.  Any ideas what the problem is?  Is this a compiler bug? |  |
		| temtronic
				|  Posted: Fri May 27, 2011 8:50 am |   |
				| Sounds like you have a 'local' variable in the printf function and not a 'global' one.
 We'd need to see your code to be sure.
 You could look at any of the examples that CCS supplies in the 'examples' folder to see how it can be done....
		| CCS newby
				|  Posted: Wed Jun 01, 2011 3:47 am |   |
				| Thanks for the repsonse. I am using this line in a function to print a value:
 printf("tempf= %f",tempf);
 The variable is defined in the function thus:  float tempf;
 This will not print the varaible correctly until I add a line such as this to the main function:  printf("Hello %lf",1.0f);
 A strange problem..!
		| SherpaDoug
				|  Posted: Wed Jun 01, 2011 5:35 am |   |
				| Send us a whole compilable program that shows the problem, preferably a very short one.  Also tell us your compiler version. _________________
 The search for better is endless.  Instead simply find very good and get the job done.
		| ERICOO
				| PRINTF NOT PRINTING FLOATING POINT NUMBERS CORRECTLY |
				|  Posted: Tue Jun 28, 2011 4:52 am |   |
				| According to temtronic it would be best if you send your code. however you be sure that all variables you using for your formular are globally declared as float or if you are simply wanting to display an integer as float e.g you want display 12 as 12.00
 first store 12 in a float type variable and display using the printf format. see below
 float newby = 12.00 (instead of 12)
 printf(lcd_putc "\f%2.2f", newby)
		| brock
				|  Posted: Wed Jun 29, 2011 9:20 am |   |
				| All,
 I am having the exact issue that CCS newby is having except that putting a print in main doesn't get me out of it, but insertion of a print in another function does.
 I even tried the following:
  	  | Code: |  	  | temp = adc_sample(i);
 printf(" PV: ADC:  %f\r",temp);
 printf(" PV: ADC:  %f\r",5.27);
 temp = 1.234;
 and all printed 0.000.
 When I inserted a printf elsewhere in the program, it works perfectly.
 There is some sort of compiler bug, I think.
 I'll submit the entire code post if requested.
		| CCS newby
				|  Posted: Wed Jun 29, 2011 9:33 am |   |
				| I also managed to get rid of the issue by putting more spaces before the %f in between the quotes on the relevant printfs. |  |
		| PCM programmer
				|  Posted: Wed Jun 29, 2011 11:54 am |   |
				| Post your PIC, #fuses and compiler version. |  |
		| brock
				|  Posted: Wed Jun 29, 2011 1:42 pm |   |
				| #FUSES INTRC,NOWDT,PUT,MCLR,NOPROTECT,NOCPD,BROWNOUT,NOIESO,NOFCMEN,NOLVP
 Compiler Version:  4.122
		| PCM programmer
				|  Posted: Wed Jun 29, 2011 1:54 pm |   |
				| But what PIC are you using ?  No one in this thread has ever stated what PIC they are using.
		| brock
				|  Posted: Wed Jun 29, 2011 2:50 pm |   |
				| Sorry - I am using a 16F887. |  |
		| PCM programmer
				|  Posted: Wed Jun 29, 2011 3:10 pm |   |
				| I made a test program and it works fine.  I ran it in MPLAB simulator (MPLAB vs. 8.70) and compiled it with CCS compiler vs. 4.122.
 Here's the result in the Output Window:
  	  | Quote: |  	  | PV: ADC:  5.67
 PV: ADC:  5.27
 PV: ADC:  5.67
 PV: ADC:  1.23
 I also ran it in hardware with a 16F887 on a PicDem2-Plus board and
 got the same result.  I only changed the '\r' at the end of each line
 into "\n\r" so it would go to a newline in the TeraTerm window.
 Here's the test program:
  	  | Code: |  	  | #include <16F887.H>
 #use delay(clock = 4000000)
 float adc_sample(int8 ch)
 return(5.678);
 int8 i;
 float temp;
 i = 0;
 temp = 1.234;
		| brock
				|  Posted: Wed Jun 29, 2011 3:52 pm |   |
				| i can make it work too...if I add another printf in a completely different routine.
 Here's the complete code file.  It should work as-is, but fail if the printf (search for CCSINFO) is commented out.
  	  | Code: |  	  | #include <16F887.h>
 #include <stdlib.h>
 #include <ctype.h>
 #include <stdio.h>
 // Setup Clock
 #use delay(internal=8M)
 // Setup the Serial Port to (9600,8,N,1)
 #use rs232(baud=9600,BITS=8,PARITY=N,STOP=1,xmit=PIN_C6,rcv=PIN_C7,)
 // Register Map
 #byte   porta   = 0x05
 #byte   portb   = 0x06
 #byte   portc   = 0x07
 #byte   portd   = 0x08
 #byte   porte   = 0x09
 #byte    pir2   = 0x0d
 #byte   sspbuf    = 0x13
 #byte   sspcon   = 0x14
 #byte   adresh   = 0x1e
 #byte   adcon0   = 0x1f
 #byte   trisa   = 0x85
 #byte   trisb   = 0x86
 #byte   trisc   = 0x87
 #byte   trisd   = 0x88
 #byte   pie1   = 0x8c
 #byte   pie2   = 0x8d
 #byte   sspcon2   = 0x91
 #byte   sspstat   = 0x94
 #byte   wpub   = 0x95
 #byte   adresl   = 0x9e
 #byte   adcon1   = 0x9f
 #byte   cm2con0   = 0x108
 #byte   eedat   = 0x10c
 #byte   eeadr   = 0x10d
 #byte   eedath   = 0x10e
 #byte   eedatl   = 0x10f
 #byte   anselh   = 0x189
 #byte   eecon1   = 0x18c
 #byte   eecon2   = 0x18d
 #bit    C2OE     = 0x108.5
 #DEFINE   POT_STEPS               1024
 #DEFINE   UPPER_CAL_LIMIT            POT_STEPS - 1
 #DEFINE LOWER_CAL_LIMIT            0x0000
 #DEFINE NOP                     0x0000
 #DEFINE WRITE_RDAC_REGISTER         0x0400
 #DEFINE   READ_RDAC_REGISTER         0x0800
 #DEFINE   STORE_RDAC_SETTING_TO_TP0   0x0c00
 #DEFINE   REFRESH_RDAC_FROM_LAST_TP   0x1000
 #DEFINE   REFRESH_RDAC_FROM_SPEC_TP   0x1400
 #DEFINE   READ_LAST_TP_ADDR_STORED   0x1800
 #DEFINE   WRITE_CONTROL_REGISTER      0x1c00
 #DEFINE   READ_CONTROL_REGISTER      0x2000
 #DEFINE PLACE_DEVICE_IN_SHUTDOWN   0x2400
 #DEFINE POT_AVERAGING_COUNT         20
 #DEFINE POT_SETTLE_TIME_MS         2
 #DEFINE   POT_COUNT               1
 #DEFINE POT_PARAMETERS            3
 #DEFINE TOTAL_POT_PARAMETER_COUNT   POT_PARAMETERS*POT_COUNT
 #DEFINE CAL_PRESENT_ADDRESS         0x0
 #DEFINE   POT_CAL_TABLE_BASE_ADDRESS   0x1
 #DEFINE CAL_FLAG               0xf0
 const  float nominal_rail_voltages[POT_COUNT] =
 0.9                              // Nominal Voltage Targets
 float   pot_cal_table[TOTAL_POT_PARAMETER_COUNT];
 void init_io()
 adcon0  &= 0xfe;
 trisb     = 0xff;
 anselh    |= 0x01;
 adcon0   |= 0x80;
 adcon1    |= 0x90;
 wpub    &= 0x00;
 adcon0    |= 0x01;
 trisc   &= 0xD7;
 sspstat  = 0x80;
 sspcon    = 0x22;
 sspcon2    = 0x0;
 portd   |= 0x10;
 trisd    = 0xef;
 float adc_sample(int target_pot)
 int       i,adc_mask;
 float      v8,sum8;
 sum8 = 0;
 adcon0 &= 0xc3;
 adc_mask = (target_pot + 1) * 32;
 adcon0 |= adc_mask;
 delay_ms(POT_SETTLE_TIME_MS);
 for (i = 0; i < POT_AVERAGING_COUNT; i++)
 adcon0 |= 0x02;
 while (adcon0 & 0x02) {}
 v8 = (float) (adresh * 256 + adresl + 2) * 4.096 / 1024;
 sum8 = sum8 + v8;                  }
 sum8 = sum8 / i;
 printf(" ADCS: %4.3f\r",sum8);  // CCSINFO:  IF I COMMENT THIS PRINT OUT, NO FLOATING POINT printf WORKs
 return sum8;
 long set_pot(long write_val)
 int     write_valh, write_vall;
 int       return_valueh,return_valuel;
 long    return_value;
 //   printf("Set Pot: WV:  %04Lx\r",write_val);
 write_valh = write_val >> 8;
 write_vall = write_val & 0x00ff;
 portd   &= 0xef;                  // Drop the CS
 sspbuf     = write_valh;               // Ship the data
 delay_us(100);                     // Manditory delay
 return_valueh = sspbuf;               // Clear the input buffer and save-off the return string.
 sspbuf     = write_vall;               // Ship the data
 portd   |= 0x10;                  // Raise CS
 return_valuel = sspbuf;               // Clear the input buffer and save-off the return string
 return_value = return_valueh * 256 + return_valuel;
 delay_ms(20);                     //  Make sure we have cleared everything out
 return return_value;
 void increment_pot(long steps)
 long    return_value, new_set_value;
 return_value =  set_pot(READ_RDAC_REGISTER);
 new_set_value = return_value + steps;
 new_set_value |= 0x0400;                        // Set the write control bit
 //   printf("RV: %04Lx, Steps: %04Lx, NV: %04Lx\r",return_value, steps, new_set_value);
 return_value =  set_pot(new_set_value);
 void decrement_pot(long steps)
 new_set_value = return_value - steps;
 //   printf("Pot: RV: %04Lx, Steps: %04Lx, NV: %04Lx\r",return_value, steps, new_set_value);
 void set_pot_to_voltage(int pot_address, float target_voltage)   // Routine sets a pot to a voltage
 float   actual_voltage;
 float   error_high, error_low;
 float   offset_voltage,cal_divisor;
 int      convergence_error;
 long   steps;
 actual_voltage = adc_sample(pot_address);
 if (target_voltage > actual_voltage)
 offset_voltage = (target_voltage - actual_voltage);
 cal_divisor = ((pot_cal_table[pot_address] - pot_cal_table[pot_address + 1])/POT_STEPS);
 error_high = (float)(offset_voltage/cal_divisor);
 steps = (long) error_high;
 printf("Note: In > Actual, Steps:  0x%04lx    %Ld\r",steps,steps);
 increment_pot(steps);
 if(target_voltage > actual_voltage)
 while (target_voltage > actual_voltage)
 increment_pot(1);
 error_high = actual_voltage - target_voltage;
 decrement_pot(1);
 error_low = target_voltage - actual_voltage;
 if (error_high < error_low)
 increment_pot(1);
 else if (target_voltage < actual_voltage)
 while (target_voltage < actual_voltage)
 decrement_pot(1);
 increment_pot(1);
 if (error_low < error_high)
 decrement_pot(1);
 convergence_error = 1;
 offset_voltage = (actual_voltage - target_voltage);
 error_low = (float)(offset_voltage/cal_divisor);
 steps = (long) error_low;
 printf("Note: Actual > In, Steps:  0x%04lx    %Ld\r",steps,steps);
 decrement_pot(steps);
 increment_pot(1);
 decrement_pot(1);
 increment_pot(1);
 decrement_pot(1);
 increment_pot(1);
 decrement_pot(1);
 if (convergence_error == 1)
 printf("ERROR!\r");
 void init_pots()                  // Routine opens the POTs RDAC register for writing
 long   return_value;
 int   i;
 //   printf("Init Pots\r");
 //  Read the value of the control register - Command 8
 return_value =  set_pot(READ_CONTROL_REGISTER);
 delay_ms(5);
 //  Write the value of the control register - Command 7
 return_value =  set_pot(WRITE_CONTROL_REGISTER | 0x02);
 delay_ms(5);
 //   printf("RV:  %04x\r",return_value);
 for (i=0; i< POT_COUNT; i++)         // Set All Pots to nominal
 set_pot_to_voltage(i,nominal_rail_voltages[i]);
 delay_ms(5);                     //  Make sure we have cleared everything out
 void load_cal_data()
 int      int_array[4],i,j;
 float   *float_ptr;
 //   printf("Load Cal Data:\r");
 for (j=0; j < TOTAL_POT_PARAMETER_COUNT; j++)
 for(i = 0; i<4 ; i++)
 int_array[i] = read_eeprom(POT_CAL_TABLE_BASE_ADDRESS+i+(4*j));
 float_ptr = int_array;
 pot_cal_table[j] = *float_ptr;
 //      printf("LCD: Addr: %02x: Value %4.8f\r",j,pot_cal_table[j]);
 void clear_cal()
 printf("CC:\r");
 write_eeprom(CAL_PRESENT_ADDRESS, 0xAA);
 delay_ms(50);
 void write_cal_parameter(int eeprom_addr, int *ptr, int range)
 int   i,eeprom_data;
 for(i = 0; i< range ; i++)
 eeprom_data = ptr[i];
 //      printf("WCP: %02x  %02x, PIE2: %02x\r",eeprom_addr+i, eeprom_data, pie2);
 write_eeprom(eeprom_addr+i, eeprom_data);
 delay_ms(30);
 //   printf("EEPROM:  ");
 //   for(i = 0; i<24 ; i++)
 //      printf("%02x  ",read_eeprom(i));
 //   printf("\r");
 void cal_pot()
 long   return_value;
 float   high_value, low_value, step_size;
 int      eeprom_data, i;
 int      *ptr;
 //   printf("Cal Pot\r");
 eeprom_data = read_eeprom(CAL_PRESENT_ADDRESS);
 if (eeprom_data != CAL_FLAG)            // Read the EEPROM - if cal flag in addr 0, then blow this step off
 for(i=0; i < POT_COUNT; i++)
 printf("No Cal Data present.  Calibrating.\r");
 return_value = set_pot(WRITE_RDAC_REGISTER | UPPER_CAL_LIMIT);
 delay_ms(10);
 high_value = adc_sample(i);
 return_value = set_pot(WRITE_RDAC_REGISTER | LOWER_CAL_LIMIT);
 delay_ms(10);
 low_value = adc_sample(i);
 printf("Addr: 0x%02x: Cal High: %4.3f, Low: %4.3f\r",i,high_value,low_value);
 ptr = &high_value;
 write_cal_parameter(POT_CAL_TABLE_BASE_ADDRESS+(i*POT_PARAMETERS),ptr,4);
 ptr = &low_value;
 write_cal_parameter(POT_CAL_TABLE_BASE_ADDRESS+(i*POT_PARAMETERS)+4,ptr,4);
 write_eeprom(CAL_PRESENT_ADDRESS,CAL_FLAG);
 step_size = (high_value - low_value)/POT_STEPS;
 ptr = &step_size;
 write_cal_parameter(POT_CAL_TABLE_BASE_ADDRESS +(i*POT_PARAMETERS)+8,ptr,4);
 delay_ms(30);
 load_cal_data();
 void print_help()
 printf("\r\r\r\r\rSPI Test\r");
 void print_volts()
 int      i;
 float temp;
 for (i=0; i  < POT_COUNT; i++)
 temp = 1.234;
 struct char_input   // character input buffer
 char *characters[10];
 int8 len;
 int1 err;
 } user_input;
 // Character input routine with backspace editing
 void get_string(int max)
 int len;
 char c;
 --max;
 len=0;
 do
 c=getc();
 if(c==8)   // Backspace
 if(len>0)
 len--;
 putc(c);
 putc(' ');
 putc(c);
 else if ((c>=' ')&&(c<='~'))
 if(len<max)
 user_input.characters[len++]=c;
 putc(c);
 } while (c!=13);
 user_input.characters[len]=0;
 user_input.len = len;
 float parse_input() {
 float   result_float;
 char   ptr[10];
 int      i;
 user_input.len = 0;         // Initialize the port variables prior to get_string call
 user_input.err = 0;
 get_string(10);            // Load the global string with command line stuff
 for (i=0;i<10;i++)         // Load the global buffer output locally - some weird compiler stuff otherwise.
 ptr[i] = user_input.characters[i];
 result_float = strtof(ptr,ptr + strlen(ptr));
 printf("\rReceived Float: %5.4f\r",result_float);
 return result_float;
 float   input_value;
 int      error;
 reset:
 print_help();
 init_io();
 cal_pot();
 init_pots();
 // Set them all to mid-range
 while (1)
 printf("> ");                     // Print the Prompt
 input_value = parse_input();
 printf("\rInput Value: %4.3f\r",input_value);
 error = 0;
 if ((input_value <= pot_cal_table[0]) && (input_value >= pot_cal_table[1]))
 set_pot_to_voltage(0,input_value);
 else if (input_value == 0)
 clear_cal();
 goto reset;
 printf("Input of range!\r");
 print_volts();
		| PCM programmer
				|  Posted: Wed Jun 29, 2011 4:52 pm |   |
				| This is too much code and it's too convoluted for me. I did notice one thing. Here you've declared an array of pointers to chars
 but you use it as an ordinary array of characters.  You should remove the *.
  	  | Quote: |  	  | struct char_input   // character input buffer
 int8 len;
 int1 err;
 } user_input;
 c=getc();
		| brock
				|  Posted: Wed Jun 29, 2011 5:11 pm |   |
				| Did you build it and see if it does what I said it does?
 I could strip it down, but then the issue probably will submerge.
 The fact remains that with this code NO printf prints floats correctly.  Comment out the line labeled CCSINFO and you should see it....
 Not that it's relevant, but but the line input works...so I don't see how the usage could be off....
 | You cannot post new topics in this forum You cannot reply to topics in this forum
