A question about ECCP[Solved]
lokken
PostPosted: Mon Jan 31, 2011 2:25 am     Reply with quote
Does PWM frequency reduce in ECCP mode?
I calculated the PWM frequency as 20 Khz.
I wrote this code shown below. But I get 5khz signal at the output of the P1D. Is it normal?
My codes; (My compiler version is 4.114)
#include <18f14k50.h>
#include <PIC18f14k50_registers.h>
#FUSES NOWDT,INTRC_IO,NOPUT,NOBROWNOUT,NOLVP,NOCPD,NOMCLR,NODEBUG
   TRISC=0b00000010;
   PORTC=0;
   t2con=0b00000100;
   ccp1con=0b00001100;
   pstrcon=0b00001000;
   pr2=50;
   CCPR1L=10;
   while(true){}
lokken
PostPosted: Wed Feb 02, 2011 8:12 am     Reply with quote
Is there anyone to answer my question?
PostPosted: Wed Feb 02, 2011 9:00 am     Reply with quote
1) Is this a real chip with a 'scope looking at the signal or a simulation(proteus ?)?
2) you should use the CCS functions for setting peripherals up, I doubt many will want to take the time to figure out what ,for example...ccp1con=0b00001100 translates to.
lokken
PostPosted: Wed Feb 02, 2011 9:52 am     Reply with quote
Ok I solved. It is all about my PIC programmer. Thanks for consideration.
chungtn
How to setup ECCP modul of 16f716
PostPosted: Thu Aug 18, 2011 12:55 am     Reply with quote
I don't know how to setup ECCP module.
Can you give me a sample program or help me setup this?
PostPosted: Thu Aug 18, 2011 1:53 pm     Reply with quote
1. What ECCP mode do you want ? Full-Bridge, or Half-Bridge, or what ?
2. What is your CCS compiler version ?
