Converting a int64 to float64 PIC24
Jakesvanzyl
PostPosted: Wed Nov 24, 2010 12:17 am     Reply with quote
I have successfully converted a float64 to a int64 with the following method.
step 1. Declare a Union
union {
    int8 b[8];
    float64 f;
} floatConversion;
step 2. set the float64 value in the main code
floatConversion.f = 3.2;
step 3. Get the 8 bytes from floatConversion.b
I have checked the values are in the correct IEEE standard and it works well
The problem I have is I want to convert the int64 back to float64 I have tried the above code in reverse but it does not work.
Can somebody please help me with this problem?
PIC = 24FJ48GA002
Wayne_
PostPosted: Wed Nov 24, 2010 3:02 am     Reply with quote
Microchip do not follow IEEE standard for float32s, the sign bit is in a different place, I assume the same applies to float64s but can not be certain.
PostPosted: Wed Nov 24, 2010 3:10 am     Reply with quote
On PCD, the floats are IEEE standard.
This is why the code in IEEEfloat.c, tests the compiler, and returns 'invalid' for PCD.
What is posted, should work 'both ways'. Not converting to an int64, but to 8*int8's though. Smile
Obvious thing really would be something wrong with the byte order into the array etc., when writing back.
Really need to use a debugger, and see if the values in the 8byte array are what is expected. If not in a debugging environment, then RS232, and print the bytes out.
