mojsa2000
| error messages |
Posted: Tue Nov 23, 2010 2:06 am |
Hi
I reinstall the original version of CCS compiler and the problem " out of rom " solved.
But now there is a new error that I can't recognize why they occur.
This is the part of program that has errors with error message on top of the related line:
#include <stdlib.h>
#include <input.c>
char cmd[5];
int1 tz_flag,ts_flag,ds_flag,dt_flag,er_flag;
int1 tz11_flag,tz12_flag,tz13_flag,tz22_flag,tz23_flag,
tz33_flag;
extern int8 tzone11,tzone12,tzone21,tzone22,tzone31,tzone32;
extern float tcoe13,tcoe23,tcoe33;
extern int8 hour,min,sec;
extern int8 day,month,year,dow;
int1 ts_h_flag,ts_m_flag,ts_s_flag;
int1 ds_d_flag,ds_m_flag,ds_y_flag;
char pc_cmd[5];
communication(){
if (kbhit())
if(tz_flag){
if(tz11_flag)
tzone11=get_int();
tz12_flag=1;
tz11_flag=0;
tzone32=tzone11;
printf("%d",32);
if(tz12_flag)
tzone12=get_int();
tz12_flag=0;
tz22_flag=1;
tzone21=tzone12;
printf("%d",32);
if(tz22_flag)
tzone22=get_int();
tz22_flag=0;
tz13_flag=1;
tzone31=tzone22;
printf("%d",32);
if(tz13_flag)
tcoe13=get_float();
tz13_flag=0;
tz23_flag=1;
printf("%d",32);
if(tz23_flag)
tcoe23=get_float();
tz33_flag=1;
tz23_flag=0;
printf("%d",32);
if(tz33_flag)
tcoe33=get_float();
tz33_flag=0;
tz_flag=0;
printf("end");
return tzone11,tzone12,tcoe13,tzone21,tzone22,tcoe23,
tzone31,tzone32,tcoe33;
if(ts_flag)
if(ts_s_flag)
sec=get_int();
ts_s_flag=0;
ts_m_flag=1;
printf("%d",32);
if(ts_m_flag)
min=get_int();
ts_m_flag=0;
ts_h_flag=1;
printf("%d",32);
if(ts_h_flag)
hour=get_int();
ts_h_flag=0;
ts_flag=1;
printf("end");
ds1307_set_time(hour,min,sec);
return hour,min,sec;
if(ds_flag)
if(ds_d_flag)
day=get_int();
ds_d_flag=0;
ds_m_flag=1;
printf("%d",32);
if(ds_m_flag)
month=get_int();
ds_m_flag=0;
ds_y_flag=1;
printf("%d",32);
if(ds_y_flag)
year=get_int();
ds_y_flag=0;
ds_flag=0;
printf("end");
ds1307_set_date(day,month,year);
return day,month,year;
if(dt_flag)
get_string(pc_cmd,4);
if(pc_cmd=="read")
data_sending();
printf("date");
ds1307_get_date(day,month,year,dow);
year=year+2000;
printf("%d/%d/%d",year,month,day);
printf("time");
ds1307_get_time(hour,min,sec);
printf("%d:%d:%d",hour,min,sec);
printf("end");
dt_flag=0;
if(er_flag)
int16 counter=0;
for(counter=0;counter<10478;counter++)
eeprom_write(0,(counter*4));
er_flag=0;
printf("end");
if(!(tz_flag|ts_flag|ds_flag|dt_flag|er_flag) ){
get_string(cmd,2);
switch (cmd){
//*** Error 27 "H:\PIC\My sources\communication.c" Line 161(18,19): Expression must evaluate to a constant
case "TZ":{
tz_flag=1;
tz11_flag=1;
//*** Error 49 "H:\PIC\My sources\communication.c" Line 164(9,12): Expecting LVALUE such as a variable name or * expression
cmd="";
printf("ready");
//*** Error 51 "H:\PIC\My sources\communication.c" Line 168(9,13): A numeric expression must appear here
case "TS":{
ts_flag=1;
ts_s_flag=1;
//*** Error 49 "H:\PIC\My sources\communication.c" Line 171(9,12): Expecting LVALUE such as a variable name or * expression
cmd="";
printf("ready");
//*** Error 51 "H:\PIC\My sources\communication.c" Line 175(9,13): A numeric expression must appear here
case "DS":{
ds_flag=1;
ds_d_flag=1;
//*** Error 49 "H:\PIC\My sources\communication.c" Line 179(9,12): Expecting LVALUE such as a variable name or * expression
cmd="";
printf("ready");
//*** Error 51 "H:\PIC\My sources\communication.c" Line 183(9,13): A numeric expression must appear here
case "RD":{
dt_flag=1;
//*** Error 49 "H:\PIC\My sources\communication.c" Line 186(9,12): Expecting LVALUE such as a variable name or * expression
cmd="";
printf("ready");
//*** Error 51 "H:\PIC\My sources\communication.c" Line 190(9,13): A numeric expression must appear here
case "ER":{
er_flag=1;
//*** Error 49 "H:\PIC\My sources\communication.c" Line 193(9,12): Expecting LVALUE such as a variable name or * expression
cmd="";
printf("ready");
//*** Error 43 "H:\PIC\My sources\communication.c" Line 199(1,2): Expecting a declaration
Wayne_
Posted: Tue Nov 23, 2010 2:59 am |
You can not use strings in a case!
case "HS": // Will NOT work.
You can use something like
if (strcmp(cmd, "HS") == 0)
else if (strcmp(cmd, "TS") == 0)
You can NOT assign strings at run time:-
cmd=""; // Will NOT work you need to use string functions
strcpy(cmd, "");
Look at the help for string functions, search google. |
Posted: Tue Nov 23, 2010 3:03 am |
Key here, is that a 'string', is an _array_ of characters, not a data type in it's own right in C. You cannot for example have:
if (fred=="message")
You need to call the strcmp function to compare the arrays.
So, switch statements, and variable assignments can't use strings (there is an exception for variable _initialisation_, where just as for filling an array with a sequence of numbers, you can intialise a character array.
Get a basic C book. This is a 'fundamental' bit of C.
mojsa2000
Posted: Tue Nov 23, 2010 7:19 am |
Hi
thanks my friends
I did this way to compare strings:
char codes[5][3]={"TZ","TS","DS","RD","ER"};
get_string(cmd,2);
if ((strcmp(cmd[0], codes[0][0])|strcmp(cmd[1], codes[0][1]))== 0){
is it legal? |
Wayne_
Posted: Tue Nov 23, 2010 9:02 am |
It would work but it is wrong. You are trying to do char comparrison but using strings.
What you are trying to do is this
get_string(cmd,2);
if ((cmd[0] == codes[0][0]) && (cmd[1] == codes[0][1])){
But you can do
get_string(cmd,2);
if (strcmp(cmd, codes[0]) == 0){
The second only works if get_string reads 2 chars in to cmd and THEN null terminates cmd making it in to a string! |
mojsa2000
Posted: Tue Nov 23, 2010 12:18 pm |
Hi again
I'm confused. I have a very big problem with the Rom vacancy.
I have made my project and when I decided to add a communication protocol to it, I couldn't.
I tried more and more and I couldn't. I said "I couldn't", not "its impossible to solve". I browsed all of posts about this
problem and they didn't usefull for me. I separated the Main to some functions and call them but it didn't fix.
| Code: | CCS PCM C Compiler, Version 4.084, 35966 23-Nov-10 17:18
Filename: the_final.lst
ROM used: 7165 words (87%)
Largest free fragment is 737
RAM used: 174 (47%) at main() level
224 (61%) worst case
Stack: 7 worst case (5 in main + 2 for interrupts)
but when added the communication protocol these error and warnings occur.why?????
protocol:
#include <stdlib.h>
#include <input.c>
char cmd[5];
tz33_flag;
char pc_cmd[5];
communication(){
if (kbhit())
if(tz_flag){
if(tz11_flag)
tzone11=get_int();
tz12_flag=1;
tz11_flag=0;
tzone32=tzone11;
printf("%d",32);
if(tz12_flag)
tzone12=get_int();
tz12_flag=0;
tz22_flag=1;
tzone21=tzone12;
printf("%d",32);
if(tz22_flag)
tzone22=get_int();
tz22_flag=0;
tz13_flag=1;
tzone31=tzone22;
printf("%d",32);
if(tz13_flag)
tcoe13=get_float();
tz13_flag=0;
tz23_flag=1;
printf("%d",32);
if(tz23_flag)
tcoe23=get_float();
tz33_flag=1;
tz23_flag=0;
printf("%d",32);
if(tz33_flag)
tcoe33=get_float();
tz33_flag=0;
tz_flag=0;
printf("end");
if(ts_flag)
if(ts_s_flag)
sec=get_int();
ts_s_flag=0;
ts_m_flag=1;
printf("%d",32);
if(ts_m_flag)
min=get_int();
ts_m_flag=0;
ts_h_flag=1;
printf("%d",32);
if(ts_h_flag)
hour=get_int();
ts_h_flag=0;
ts_flag=1;
printf("end");
if(ds_flag)
if(ds_d_flag)
day=get_int();
ds_d_flag=0;
ds_m_flag=1;
printf("%d",32);
if(ds_m_flag)
month=get_int();
ds_m_flag=0;
ds_y_flag=1;
printf("%d",32);
if(ds_y_flag)
year=get_int();
ds_y_flag=0;
ds_flag=0;
printf("end");
if(dt_flag)
if(pc_cmd=="read")
data_sending();
printf("date");
year=year+2000;
printf("time");
printf("end");
dt_flag=0;
if(er_flag)
int16 counter=0;
er_flag=0;
printf("end");
get_string(cmd,2);
tz_flag=1;
tz11_flag=1;
strcpy(cmd,"");
printf("ready");
if ((strcmp(cmd[0], codes[1][0])|strcmp(cmd[1], codes[1][1]))== 0){
ts_flag=1;
ts_s_flag=1;
strcpy(cmd,"");
printf("ready");
if ((strcmp(cmd[0], codes[2][0])|strcmp(cmd[1], codes[2][1]))== 0){
ds_flag=1;
ds_d_flag=1;
strcpy(cmd,"");
printf("ready");
if ((strcmp(cmd[0], codes[3][0])|strcmp(cmd[1], codes[3][1]))== 0){
dt_flag=1;
strcpy(cmd,"");
printf("ready");
if ((strcmp(cmd[0], codes[4][0])|strcmp(cmd[1], codes[4][1]))== 0){
er_flag=1;
strcpy(cmd,"");
printf("ready");
error&warning:
| Code: | >>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@I2C_WRITE_1)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@I2C_READ_1)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (bcd2bin)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (bin2bcd)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@delay_ms1)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@SFTOI)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@MULFF)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@DIVFF)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@ADDFF)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@ITOF)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@DIV1616)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@DIV88)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (eeprom_read)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@FTOSD)
>>> Warning 216 "the_final.c" Line 376(0,1): Interrupts disabled during call to prevent re-entrancy: (@DIV3232)
*** Error 71 "the_final.c" Line 376(0,1): Out of ROM, A segment or the program is too large read_daily_vi
Seg 01800-01FFF, 0011 left, need 0059
Seg 00000-00003, 0000 left, need 0059
Seg 00004-0004D, 0000 left, need 0059
Seg 0004E-007FF, 0008 left, need 0059
Seg 00800-00FFF, 000B left, need 0059
Seg 01000-017FF, 0004 left, need 0059 |
arocholl
Posted: Tue Nov 23, 2010 12:47 pm |
| Wayne_ wrote: | You can not use strings in a case!
Yes, you can with CCS v4.1xx, see http://www.ccsinfo.com/content.php?page=V4.1xx , they extended beyond standard C for that.
Probably the user was working with a 4.1xx version and working fine. After he reinstalled an older version, it didn't compile anymore. |
gpsmikey
Posted: Tue Nov 23, 2010 2:01 pm |
Hey, I've always wanted to use "strings" in a case statement in C -- thanks for pointing out that enhancement in 4.1xx !
mikey _________________ mikey
Wayne_
Posted: Wed Nov 24, 2010 2:43 am |
| arocholl wrote: | | Wayne_ wrote: | You can not use strings in a case!
Well spotted  |
Wayne_
Posted: Wed Nov 24, 2010 2:52 am |
This is not possible in standard C and I doubt CCS has implemented it somehow. Don't know why the compiler is not complaining. Your code works because these are globals anyway.
In fact the function itself is flawed, your function header does not specify a return yet in some parts it exits the function with returns + parameters and in others it does not. I think you are just lucky the compiler is ignoring the values after the return statements.
I am sure you know why you are getting the interrupts disabled warnings.
To fix the out of ROM you need to use a different chip or reduce the amount of rom you are using.
Move some consts to ram.
Remove duplicated functions.
You have some space left but not enough for your code.
The last piece you posted has a lot of duplication:-
strcpy(cmd, "");
printf("ready");
I am sure a little re-arranging of this part can reduce that. |
