18F4550 ECCP help
aruna1
18F4550 ECCP help
PostPosted: Thu Nov 18, 2010 9:01 pm     Reply with quote
Hi I read 18F4550 has a ECCP module so it has 4 pwm pins for ccp1 (C2,D5,D6,D7).
My question is can I use this 4 pins to generate 4 distinct pwm signals with different pulse widths (but with same frequency).
Its pretty hard to understand on the data sheet. From what I understand it can do that. But I want to be sure. So some good explanation is welcome.
Thank you
compiler version 4.084
PostPosted: Thu Nov 18, 2010 10:27 pm     Reply with quote
You can't do it with the 18F4550. It only has one PWM generator module
for those 4 pins.
To get 4 or more PWM channels, you need to use a PIC such as the
18F4431 series:
http://www.ccsinfo.com/forum/viewtopic.php?t=37206
aruna1
PostPosted: Thu Nov 18, 2010 11:28 pm     Reply with quote
for those 4 pins.
18F4431 series:
so what is the point of having P1A,P1B,P1C,P1D (C2,D5,D6,D7)?
here i have attached(google doc) halfbridge mode of CCP1 pin.
take a look. it seems it generates two distinct pwms
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B9bkKc15uKquZWZhZGVmN2YtODEyYi00NGVlLWI0YzEtNTFmMzM5NWE5ZGQ3&hl=en
PostPosted: Thu Nov 18, 2010 11:41 pm     Reply with quote
No, it doesn't. Half-Bridge mode generates two opposite phases of the
same signal, with an optional dead-band delay. That is not what you
aruna1
PostPosted: Thu Nov 18, 2010 11:47 pm     Reply with quote
oh i thought they are two distinct pwms?
so its just a fake lol
thank you pcm programmer
PostPosted: Fri Nov 19, 2010 3:12 am     Reply with quote
Not really a 'fake', but I think it is poorly described in parts of the Microchip documentation. As PCM says, on the ECCP, you have one 'timing generator', with the ability to drive Half-bridge, or full bridge timing patterns onto four pins, from this one generator. Microchip have the 'habit', of saying 'X PWM pins', and not of saying how many actual timing generators are available. The 'power PWM' module conversely, allows multiple different pulse widths on it's different pins (designed for doing things like synthesising multiple AC phases). It'd be really 'nice' if Microchip would say something like 'X PWM timing generators (y with the ability to generate full-bridge/half bridge outputs on separate pins)'. Might just make it a fraction easier to find the one with extra generators when you want it!.....
aruna1
PostPosted: Sat Nov 20, 2010 9:10 pm     Reply with quote
oh I see Smile
Thank you Ttelmah
