Printf used in dsPIC33f
cchappyboy
PostPosted: Wed Nov 17, 2010 3:07 pm     Reply with quote
I used dsPIC33F want to print out:
0 CrLf
1 CrLf
2 CrLf
3 CrLf
4 CrLf
A CrLf
The program like this
for(i=0;i<5;i++)
 printf("%2x",i);
 printf("\r\n");
printf("A");
But what I get from the PC are
70 70 0D 0A 70 71 0D 0A 70 72 0D 0A 70 73 0D 0A 70 74 0D 0A 81
Is there something I missed? I am appreciate any help in advance.
jds-pic
Re: Printf used in dsPIC33f
PostPosted: Wed Nov 17, 2010 4:03 pm     Reply with quote
0 CrLf
for(i=0;i<5;i++)
what size is i? int8? int16?
cchappyboy wrote:
printf("%2x",i);
what does your CCS manual say about the %x printf format specifier?
what effect does the '2' have upon this specifier?
jds-pic
jds-pic
PostPosted: Wed Nov 17, 2010 4:08 pm     Reply with quote
I have highlighted the CR/LF above.
I have highlighted variable "i" above.
What program are you using on the PC end?
jds-pic
cchappyboy
PostPosted: Wed Nov 17, 2010 4:52 pm     Reply with quote
Thanks for your response.
I did some changes:
#use rs232(baud=9600,xmit=pin_f5,rcv=pin_f4,bits=8,stop=1,parity=n)
   unsigned int8 i=0;
   for(i=0;i<5;i++)
      printf("%d",i);
      printf("\r\n");
   printf("How are you?");
But this time it still not right.
It shows on Hyper terminal,
p
q
r
s
t
ˆÏ÷@ÁòÅ@ùÏõ
there should be
0
1
2
3
4
How are you?
jds-pic
PostPosted: Wed Nov 17, 2010 9:35 pm     Reply with quote
cchappyboy wrote:
unsigned int8 i=0;
printf("%d",i);
Check your manual... is "%d" used for signed int or unsigned int?
Do not use Hyperterminal for debugging serial problems -- it stinks. So download and install TeraTerm or other (good) serial terminal program. Ensure that the bits/parity/stop settings are the same at both ends. I think this is the root cause of your problem.
jds-pic
Wayne_
PostPosted: Thu Nov 18, 2010 3:13 am     Reply with quote
jds-pic is correct, you should be using %u but it shouldn't matter in this case.
The output you show would imply an incorrect baud, bits, parity settings between your PC/term prog and the pic or a hardware/cable problem, you have got RS232 driver chip on your circuit, haven't you?
70 shown in your first post is hex 0x70 = 'p' = 0b01110000 it should be 0x30 = '0' = 00110000 this matches your latest output with using %d to display the decimal value rather than the hex.
%d converts the number 0 to the char '0' and when output hyperterm is displaying 'p'.
More importantly, show your whole program, not just these little snippets!
And yes Hyperterminal is crap but it should still work for this.
PostPosted: Thu Nov 18, 2010 3:49 am     Reply with quote
Yes.
A simple look, says '70' (hex), is the letter 'p'.
The number '0', is '30', so what the PC is seeing is the signal being high for three bit times (at RS232 levels), when it is only meant to be seeing two high bit times.
Implies baud, is either 50% slow at the PIC, or 50% fast at the PC (in fact, depending on the PC's 'sampling strategy', anything over perhaps 30% slow would give this).
Start simple. Do a basic 1 second LED flash program, and with a stopwatch, count thirty flashes. 30seconds?. If not, the crystal is wrong,or one of the fuse settings, so the PIC is not running at the speed required.
cchappyboy
PostPosted: Thu Nov 18, 2010 10:51 am     Reply with quote
Thanks you guys.
According your guys analysis, I try so many way to find out what is going on there. Finally I make a 1 second led flash program as Ttelmah said. I found it was 1.07 seconds other than 1 second. So I try use chips internal clock then it works properly. So i think I need to change the crystal.
Thanks again.
jds-pic
PostPosted: Thu Nov 18, 2010 11:44 am     Reply with quote
the clock variation that you document above (+7%) is outside the generally accepted RS232 frequency tolerance of +/-3%. some implementations will be more tolerant, some less so, but 3% is a good starting point.
see also
http://www.maxim-ic.com/app-notes/index.mvp/id/2141
jds-pic
cchappyboy
PostPosted: Thu Nov 18, 2010 12:02 pm     Reply with quote
Thanks JDS-PIC
