mmc card error with 18f4620 and enc28j60
OpenSys
PostPosted: Sat Nov 13, 2010 3:10 pm     Reply with quote
I use the ccs example ex_st_webserver2 to test mmc card in fat32, but always return MMC_EC_NOT_IDLE in mmc_init.
I check all hardware connection and seems ok, I also have shared the SPI pins with Ethernet controller.
I use a 128M 2G and 4G mmc cards, I get the same error.
I get IP address and lcd show IP address.
The web page also shows "500 Error"
I use a 10mhz crystal.
Config pins:
 #define EXT_FLASH_PIN_SCL     PIN_C3 //o
 #define EXT_FLASH_PIN_SDI     PIN_C4 //i
 #define EXT_FLASH_PIN_SDA     PIN_C5 //o
 #define EXT_FLASH_PIN_SELECT  PIN_C2
Please point me in the right direction.
Vasco Santos
andrewg
PostPosted: Sat Nov 13, 2010 8:57 pm     Reply with quote
I don't use that particular library, but that sounds like an SPI clock idle problem.
.... Yes, the ENC28J60 is a mode 0 device, while the SD card is mode 3. Those use opposite clock polarities. You'll probably need to call spi_setup every time you switch between devices to set the bus into the correct mode.
Andrew
OpenSys
PostPosted: Sun Nov 14, 2010 5:58 am     Reply with quote
thank you for your answer.
So best way is set other pins in pic do run the spi, the clock, sdi and sdo right?
What driver you use ?
andrewg
PostPosted: Sun Nov 14, 2010 7:43 am     Reply with quote
I use mmcsd.c/fat.c, while you're using mmc_spi.c, right?
I don't understand your question.
Actually, having a look at mmc_spi.c I can see that it is 'bit banging' the SPI bus, while the ethernet driver will be using the hardware SPI peripheral.
I would recommend switching to mmcsd.c which can be configured to use hardware SPI. Then I would try adding setup_spi calls to switch to the correct mode before you use each device.
Andrew
OpenSys
PostPosted: Sun Nov 21, 2010 7:45 am     Reply with quote
Thank you,
But this mmc only works if the Ethernet module is off, so I pass the webpages to one eeprom with mpfs but have a problem reading the web page, I post it in:
http://www.ccsinfo.com/forum/viewtopic.php?t=44073
Regards.
VS
andrewg
PostPosted: Sun Nov 21, 2010 8:35 am     Reply with quote
I've not used mpfs, so I can't help you there, but I can say that I have successfully mixed different mode SPI devices - Mode 0 for the Ethernet chip and Mode 1 for a DS1307 RTC. I modified the RTC driver to switch to Mode 1 before any data transfer and switch back to Mode 0 when finished. You will need to do something similar - switch to Mode 3 before any SD accesses and switch back to Mode 0 before allowing the Ethernet library to do its thing.
Andrew
OpenSys
PostPosted: Sun Nov 21, 2010 12:58 pm     Reply with quote
Thank you for all your help, now I fixed it with eeprom Smile
