ADC with Pic 16f887
William
ADC with Pic 16f887
PostPosted: Wed Oct 27, 2010 2:37 am     Reply with quote
Hi I'm writing a program that needs to read the temperature from four temperature sensors, LM35DZ's. And it needs to read them from Pin B0, B1, B2 and B3. the problem is that I can't even get one working and I'm sure its the code because when I measure the output voltage from the Vout of the temperature sensor and its right. Here is the code:
#include <16F887.H>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
      int8 val;
      SETUP_ADC_PORTS(sAN9 | VSS_VDD);
      SETUP_ADC(ADC_CLOCK_INTERNAL);
      SET_ADC_CHANNEL(0);
while(1){
      delay_ms(18);
      val = READ_ADC();
      printf("%u ",val);
The output of this is just random numbers that keep getting smaller.
Now there are a few questions that I have to ask: What does "SET_ADC_CHANNEL(0);" do?
What is the right Clock to set "SETUP_ADC(ADC_CLOCK_INTERNAL);" too?
Any help would be greatly appreciated.
Thanks!
PostPosted: Wed Oct 27, 2010 4:11 am     Reply with quote
First, the setup_adc command selects which ports pins are going to be configured for use by the ADC. You have this selecting sAN9. Pin B3. OK. Then the set_adc_channel command, selects which channel is connected through the multiplexer to the actual ADC input. Currently you have this selecting channel 0, which connects to pin A0.....
So, start by selecting the channel you have got enabled for ADC operation. 9.
Then look at your ADC clock setting. Go to table 9-1 in the data sheet. Read Note 4 here. Is ADC_CLOCK_INTERNAL right?. Look at the table itself, and the value that is recommended for 4MHz operation.
For the multiple channels, you will need the setup_adc command to have all four pins you want 'enabled' (or them together in the command), then you select these one at a time, wait a moment (you only need a few uSec, not the 18mSec you are using - section 9-3 of the data sheet), and then take the reading, and move to the next channel.
William
PostPosted: Wed Oct 27, 2010 7:23 am     Reply with quote
Thanks! that really helped!
