nina
nibble |
Posted: Sun Jul 04, 2010 9:14 pm |
humberto
00010011 & 0x0F (11110000) result 00010000 (16 dec).
Could you explain this math?
tks
nina |
Humberto
Posted: Mon Jul 05, 2010 9:29 am |
Quote: |
I am not using 7445. Display one and display two are conected directly to pic. How can I display those numbers?
Use this table assignment to drive each segment of the display directly from the PIC:
Code: | // character 0 1 2 3 4 5 6 7 8 9
byte const Digit_Map[10] = {0xFC,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xE6};
Wire the MSB of the selected port (Ex PortB: B7 to segment a, B6: seg b, B5: seg c ... B1:seg g)
I never post what you remark.
Binary 0b11110000 is equal to HEX 0xF0 NOT 0x0F as you post.
x = 0x13 & 0xF0 // in HEX
x = 0b000100011 & 0b11110000 // in Binary
AND two binary values
0b00010011 // 0x13
0b11110000 // 0xF0
____________
0b00010000 // 0x10
Please use MPLAB to test and simulate all this math.
Humberto
nina
nibble |
Posted: Mon Jul 05, 2010 10:18 am |
humberto
binary 0b00010000 is not 16 in dec? This point I can not understand.
bin dec hex
0000 0001 01 01
0001 0000 16 10
Tks
nina |
Humberto
Posted: Mon Jul 05, 2010 10:54 am |
0b000100000 YES it is equal to decimal 16.
I showed you how to handle a binary number >100 using a single algoritm to convert it to BCD
in two nibbles. These two nibbles does not have any mathematical equivalent to any Decimal number,
just is a BCD value that can not be used for any math. I guess that this is what you do not figure out.
Once converted a binary value, the resulting value to drive a display segments, like 0b000100000
does not matter if is equal to a decimal number, it´s just a value that will do what you need.
Humberto |
