CCS CAN bus demo board ex_can_ccs_a.c [solved]
Benzino
PostPosted: Tue Mar 02, 2010 12:44 pm     Reply with quote
Has anyone come across with the read_adc() issue using ex_can_ccs_a.c file on the CCS CAN bus demo board?
I have my CAN stuff working for both node a and b (I took node c and d out because I tested only these two).
Note: node a is 18F4580 and node b is 16F876
Using the example from CCS, I was be able to read the ADC on node b without any problems. Below is my code
#include <16F876A.h>
#device ADC=10
#fuses HS,NOPROTECT,NOLVP,NOWDT
#use delay(clock=2500000)
#include "can-mcp2510.c"
#define RED_LED     PIN_A1
#define YELLOW_LED  PIN_A2
#define GREEN_LED     PIN_A3
int16 ms;
#int_timer2
void isr_timer2(void) {
   ms++; //keep a running timer that increments every milli-second
   int32 rx_id;
   int rx_len, rxstat, buffer[8];
   int out_data[8];
   int16 i;
   output_bit(YELLOW_LED, 1);
   output_bit(GREEN_LED, 1);
   output_bit(RED_LED, 1);
   buffer[0] = 0x00;
   buffer[1] = 0x00;
   buffer[2] = 0x00;
   buffer[3] = 0x00;
   buffer[4] = 0x00;
   buffer[5] = 0x00;
   buffer[6] = 0x00;
   buffer[7] = 0x00;
   setup_timer_2(T2_DIV_BY_4,79,16);   //setup up timer2 to interrupt every 1ms if using 20Mhz clock
   setup_port_a(RA0_ANALOG);
   set_adc_channel(0);
   printf("\r\nStart CAN initialization");
   can_init();
   printf("\r\nCAN initialization complete");
   enable_interrupts(INT_TIMER2);   //enable timer2 interrupt
   enable_interrupts(GLOBAL);       //enable all interrupts (else timer2 wont happen)
   while(TRUE) {
      if ( can_kbhit() ) {
      if(can_getd(rx_id, &buffer[0], rx_len, rxstat))
      if (rx_id == 0x201) {
         if(buffer[0]==0x01) // buffer[0]&2
            printf("\r\nreceive rx=201 data=1");
            output_bit(GREEN_LED, 0);
            buffer[0] = 0x01;
            buffer[1] = 0x00;
            buffer[2] = 0x00;
            buffer[3] = 0x00;
            buffer[4] = 0x00;
            buffer[5] = 0x00;
            buffer[6] = 0x00;
            buffer[7] = 0x00;
         if(buffer[0]==0x02) // buffer[0]&4
            printf("\r\nreceive rx=201 data=2");
            output_bit(YELLOW_LED, 0);
            buffer[0] = 0x02;
            buffer[1] = 0x00;
            buffer[2] = 0x00;
            buffer[3] = 0x00;
            buffer[4] = 0x00;
            buffer[5] = 0x00;
            buffer[6] = 0x00;
            buffer[7] = 0x00;
         if(buffer[0]==0x0A) // buffer[0]&8
            printf("\r\nreceive rx=201 data=A");
            output_bit(RED_LED, 0);
            buffer[0] = 0x0A;
            buffer[1] = 0x00;
            buffer[2] = 0x00;
            buffer[3] = 0x00;
            buffer[4] = 0x00;
            buffer[5] = 0x00;
            buffer[6] = 0x00;
            buffer[7] = 0x00;
      if (rx_id == 0x202){
         printf("\r\nreceive rx=202");
         buffer[0] = 0x1A;
         buffer[1] = 0x2B;
         buffer[2] = 0x3C;
         buffer[3] = 0x4D;
         buffer[4] = 0x5E;
         buffer[5] = 0x6F;
         buffer[6] = 0x00;
         buffer[7] = 0x00;
      //every one second, send new data if transmit buffer is empty
      if ( can_tbe() && (ms > 100))
         ms=0;
         i=can_putd(0x452, buffer, 8,1,0,0); //put data on transmit buffer
       printf("\r\n");
         if (i != 0xFF) { //success, a transmit buffer was open
            for (i=0;i<8;i++) {
               printf("%X ",buffer[i]);
       i=read_adc();
       printf("Sending AD reading: %Lu",i);
       i=can_putd(0x453, &i, 2,1,0,0);
       } else { //fail, no transmit buffer was open
            printf("\r\nFAIL on PUTD\r\n");
Now when I tried to read in ADC from AN0 base on ex_can_ccs_a.c, it stalls on that read_adc() function.
Here is what I received on my Hyper terminal
CCS CAN Example
CAN ID: 268 (dec) 010C (hex)
The current CAN ID: 268
Running...
Sending LED input
Read ADC input
Here is my code for the node a
#include <18F458.h>
#device ADC=10
//#define CAN_DO_DEBUG TRUE
#include "can-18xxx8.c"
#define PIN_LED1  PIN_A5
#define PIN_LED2  PIN_B5
#define PIN_LED3  PIN_B4
#define LED1_HIGH output_low(PIN_LED1)
#define LED1_LOW  output_high(PIN_LED1)
#define LED2_HIGH output_low(PIN_LED2)
#define LED2_LOW  output_high(PIN_LED2)
#define LED3_HIGH output_low(PIN_LED3)
#define LED3_LOW  output_high(PIN_LED3)
#define BUTTON    PIN_A4
#define BUTTON_PRESSED  !input(BUTTON)
#define CAN_BATT_PACK1   0x104   // Tx 260 (dec)
#define CAN_BATT_PACK2   0x106   // Tx 262 (dec)
#define CAN_BATT_PACK3   0x108   // Tx 264 (dec)
#define CAN_BATT_PACK4   0x10A   // Tx 266 (dec)
#define CAN_BATT_PACK5   0x10C   // Tx 268 (dec)
#define CAN_BATT_PACK6   0x10E   // Tx 270 (dec)
#define CAN_BATT_PACK7   0x110   // Tx 272 (dec)
#define CAN_BATT_EMERG   0x96   // Tx 150 (dec)
int16 ms;
#int_timer2
// Setup CAN ID for the board looking at DIP switch input from port D
long setup_CANID()
   int i;
   i = input_d();
   switch (i)
      case 1:    printf("\r\nCAN ID: %Lu (dec) %LX (hex)", CAN_BATT_PACK1, CAN_BATT_PACK1);
               return CAN_BATT_PACK1;
      case 2:    printf("\r\nCAN ID: %Lu (dec) %LX (hex)", CAN_BATT_PACK2, CAN_BATT_PACK2);
               return CAN_BATT_PACK2;
      case 4:    printf("\r\nCAN ID: %Lu (dec) %LX (hex)", CAN_BATT_PACK3, CAN_BATT_PACK3);
               return CAN_BATT_PACK3;
      case 8:    printf("\r\nCAN ID: %Lu (dec) %LX (hex)", CAN_BATT_PACK4, CAN_BATT_PACK4);
               return CAN_BATT_PACK4;
      case 16:    printf("\r\nCAN ID: %Lu (dec) %LX (hex)", CAN_BATT_PACK5, CAN_BATT_PACK5);
               return CAN_BATT_PACK5;
      case 32:    printf("\r\nCAN ID: %Lu (dec) %LX (hex)", CAN_BATT_PACK6, CAN_BATT_PACK6);
               return CAN_BATT_PACK6;
      case 64:   printf("\r\nCAN ID: %Lu (dec) %LX (hex)", CAN_BATT_PACK7, CAN_BATT_PACK7);
               return CAN_BATT_PACK7;
      case 128:    printf("\r\nCAN ID: %u (dec) %LX (hex)", CAN_BATT_EMERG, CAN_BATT_EMERG);
               return CAN_BATT_EMERG;
      default:    printf("\r\nIncorrect DIP switch selection, assigned CAN ID %Lu (dec) %LX (hex) by DEFAULT", CAN_BATT_PACK1, CAN_BATT_PACK1);
   struct rx_stat rxstat;
   long rx_id;
   long tx_id;
   int buffer[8];
   int rx_len;
   int16 i;
   for(i=0;i<8;i++) {
      buffer[i]=0;
   LED1_HIGH;
   LED2_HIGH;
   LED3_HIGH;
   printf("\r\n\r\nCCS CAN EXAMPLE\r\n");
   LED1_LOW;
   LED2_LOW;
   LED3_LOW;
   setup_adc_ports(AN0);
   set_adc_channel(0);
   delay_us(20);
   can_init();
   tx_id = setup_CANID();
   printf("\r\nThe current CAN ID: %Lu", tx_id);
   printf("\r\nRunning...");
   // Test data
   buffer[0] = 0x02;
   buffer[1] = 0x00;
   buffer[2] = 0x00;
   buffer[3] = 0x00;
   buffer[4] = 0x00;
   buffer[5] = 0x00;
   buffer[6] = 0x00;
   buffer[7] = 0x00;
      if ( can_kbhit() )
      if ( can_tbe() && (ms > 1000))       //every two seconds, send new data if transmit buffer is empty
        ms=0;
      printf("\r\nSending LED input");
      can_putd(0x201, buffer,8,1,0,0);
      printf("\r\nRead ADC input");
      i = read_adc();
      delay_us(20);
      printf("\r\nSending ADC reading: %Lu", i);
      can_putd(tx_id, &i,2,1,0,0);
      if (BUTTON_PRESSED) {
         while (BUTTON_PRESSED) {}
         //delay_ms(200);
      printf("\r\nButton is pressed");
There is a few changes on can-18xxx8.c which is the CAN ID type i.e. from extended to standard.
All the hardware components are from CCS CAN bus demo board except additional 8-bit DIP switch connected to port D.
I went around and found a few posts related to ADC that I am looking for e.g. "problem with A/D" posted by PCM programmer and tried to adjust my code similar to it but nothing shows up.
Is there a way to debug read_adc() function? or any suggestion of what might cause this issue? I tried fews things before I post it on the forum but none are helpful.
Please advice,
Benzino
PostPosted: Tue Mar 02, 2010 2:13 pm     Reply with quote
ok, my bad apparently the 18F458 and 18F4580 is quite different for ADC pin and value. Confused
Sorry about posting silly question. Sad
