ICD-U64 Stream names
Allan
PostPosted: Sat Feb 20, 2010 9:50 pm     Reply with quote
Hi everybody,
I need a way to keep the debugger serial info and my program serial information separate.
The best way seems to be to use fprintf instead of printf and specify the name of the desired stream. However, I can't find the name of the debugger input and output streams.
Anybody know them, or another way to keep the data separate?
Thanks, Al
PostPosted: Sun Feb 21, 2010 1:02 am     Reply with quote
Download the CCS manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look at the list of parameters available in this section:
#USE RS232
You'll immediately see the stream parameter used for the ICD.
Also see this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=30627
