120 KHz Carrier Signal
iruraz
PostPosted: Thu Feb 18, 2010 5:10 am     Reply with quote
Hi Everyone,
I try to obtain 120 KHz carrier signal with using pwm module of pic 16f877 . PWM uses timer2 and maximum frequency value is 250 Hz because pr2 maximum value is 255 and postscale maximum value is 16. And the formula is :
Tpwm=Tcommand*(pr2 + 1)*(tmr2 division ratio)
And here is the code below. How can i obtain 120KHz signal with pwm.
regards
#include <16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=4000000)
#use fast_io(c)
void main ( )
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   set_tris_c(0x00);
   setup_ccp1(CCP_PWM);
   setup_timer_2(T2_DIV_BY_16,255,16);
   set_pwm1_duty(30);
monsters_inc
PostPosted: Thu Feb 18, 2010 5:53 am     Reply with quote
Hi. With oscillator of 4MHz you can't obtain exact 120Khz. You can obtain 125Khz.
PostPosted: Thu Feb 18, 2010 6:01 am     Reply with quote
A handy PWM calculator: http://www.micro-examples.com/public/microex-navig/doc/097-pwm-calculator.html
It will show you a table with all possible frequencies.
This is an invalid configuration and may cause problems. Change to
setup_spi(FALSE);
PostPosted: Thu Feb 18, 2010 8:14 am     Reply with quote
I have a strange suspicion, he may be after 120Hz (not 120kHz...). 244Hz, is the _minimum_ frequency from the PWM (all dividers at maximum), with a 4MHz crystal, which is what he shows.
A search here will find some answers.
Generally the 'point' of the PWM, is to allow frequencies _above_ those that can be handled by other solutions, to be generated without too much processor overhead. A 120Hz PWM, can be generated by using a normal timer interrupt instead.
The 'answer' depends massively on what is really required. Number of resolution steps, what else the processor needs to do at the same time, etc. etc..
