mickey231bhq
Posted: Tue Feb 02, 2010 4:41 am |
| I am waiting for a solution. |
tester
| Re: Bug Fixed? |
Posted: Tue Feb 02, 2010 3:26 pm |
| DerWolf wrote: | Hello,
I just wanted to start trying OSA and have read about this problem. Is this bug fixed again, as I just bought the new ccs Compiler?
Thanx |
This is a compiler's bug. It came in 4.104. (This bug is absent in previous versions). |
tester
mickey231bhq
Posted: Thu Mar 11, 2010 3:21 am |
I tried the version 4.105 the implementation, compiler bug has disappeared, all are good.  |
tester
Posted: Thu Mar 11, 2010 3:36 am |
| mickey231bhq wrote: | I tried the version 4.105 the implementation, compiler bug has disappeared, all are good.  | Thank's for information! I will check this version more detailed as soon as possible.
Promo: OSA is ported for AVR (compilers WinAVR and IAR)
http://wiki.pic24.ru/doku.php/en/osa/ref/download/intro |
skoberlink
Posted: Fri Jul 09, 2010 10:45 am |
Hey I'm having some problems getting the current version of OSA to compile. I'm using CCS version 4.038. I've added the osa directory to my include path but I keep getting this error:
| Quote: | *** Error 18 "X:\xxx\xxx\xxx\osa\osa.h" Line 1137(10,30): File can not be opened
Not in local "port\osa_include.h"
I know this means it can't find the file but I'm really not sure why. The file is exactly where it's supposed to be. This is just a test project so it's pretty much the simplest OSA project one can make. Any ideas on why it won't compile? |
tester
Posted: Mon Jul 12, 2010 5:06 am |
| skoberlink wrote: | Hey I'm having some problems getting the current version of OSA to compile. I'm using CCS version 4.038. I've added the osa directory to my include path but I keep getting this error:
Describe the sequence of operations when you create the project. There should not be any trouble when all done correcly. |
skoberlink
Posted: Mon Jul 12, 2010 8:41 am |
| tester wrote: | | skoberlink wrote: | Hey I'm having some problems getting the current version of OSA to compile. I'm using CCS version 4.038. I've added the osa directory to my include path but I keep getting this error:
I'm using CCS to compile but MPLAB for the IDE. It all seems to be properly set up for the PIC18F2620. I #include the osa.h and device files. OSAcfg.h is in the project but not included by my .c file. Since I'm using CCS I did not #include the osa.c file. I also added the two file paths to my include search path. I just click "build all" and let it do it's thing. That's when I get the error above.
In case it's relevant here's the code:
| Code: | #include <18F2620.h>
#include <osa.h>
void main(void) {
OS_Init();
OS_Run;
Like I said just the simplest possible project. I was just trying to see if I could get it to compile before I went any farther. |
tester
Posted: Mon Jul 12, 2010 8:45 am |
All correctly.
Does your project path contains any non-english letters? MPLAB doesn't like them. Can you attach your project (whole) here, I'll check it?
Try to do build example from "osa\|example\ccs" |
skoberlink
Posted: Mon Jul 12, 2010 9:07 am |
No there aren't any non-english characters.
Here's the project file: http://rapidshare.com/files/406544171/RTOS_test.rar
I tried to build the ccs examples but I can't get it to find the osa.h file no matter what I include in the search path... |
tester
Posted: Mon Jul 12, 2010 9:14 am |
| skoberlink wrote: | No there aren't any non-english characters.
The Rapidshare says: "This Account has expired." It does not allow to download the file. Send it to me via e-mail: osa@pic24.ru |
skoberlink
Posted: Mon Jul 12, 2010 9:24 am |
| Alright, I sent it. Sorry the link didn't work. I uploaded it not 5 minutes ago and it still works for me. Maybe it's a country thing... |
tester
Posted: Mon Jul 12, 2010 9:37 am |
| skoberlink wrote: | | Alright, I sent it. Sorry the link didn't work. I uploaded it not 5 minutes ago and it still works for me. Maybe it's a country thing... |
I have received your project. The problem is in CCSC.EXE: it doesn't like <spaces> in project paths. Your project located in "RTOS test" foulder. When I moved it into "RTOStest" (same without <space>), all became fine.
(Same about the foulder's name "Lumec Control Product" in the path) |
skoberlink
Posted: Mon Jul 12, 2010 9:51 am |
| hmmm...it's still giving the same error. It can't find "port/osa_include.h" I took out the <space>, changed the search path accordingly. I'm not sure what else could be wrong. Any other suggestions? Is there a specific place I should be putting the osa folder? |
tester
Posted: Mon Jul 12, 2010 9:58 am |
| skoberlink wrote: | | hmmm...it's still giving the same error. It can't find "port/osa_include.h" I took out the <space>, changed the search path accordingly. I'm not sure what else could be wrong. Any other suggestions? Is there a specific place I should be putting the osa folder? |
You didn't understand: you must to move your project into the foulder that does not contains any spaces.
The trouble is that ccsc.exe splits command's "+I" parameter when meets a <space> symbol.
Step by step:
1. Create a foulder "x:\LCP\Engineering\Andy\RTOStest"
2. Place osa intro "x:\LCP\Engineering\Andy\OSA"
3. Move there files main_test.c and osacfg.h
4. Create a new project in MPLAB in the just created foulder.
5. Add file main_test.c into the project
6. Add include path "x:\LCP\Engineering\Andy\RTOStest"
7. Add include path "x:\LCP\Engineering\Andy\OSA" |
