desertkids
FlashMemory-PIC-USB-PC???? |
Posted: Thu Jan 28, 2010 1:17 am |
Hi, just one question here. Can I design my PIC like a USB pendrive?
Means I connect a flash memory with my PIC, then connect my PIC to
PC with USB. From PC can see and manage my storage, like copy or
delete a file that store in the flash memory. Thanks for those can give me idea. |
ELCouz
Posted: Thu Jan 28, 2010 1:25 am |
If by flash memory you mean CompactFlash or MMC then yes of course but it will be painfully slow !
If you want to talk to the flash memory chip directly I think you will need a memory controller for that (too many I/O ? ) _________________ Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy! |
arunb
RE: |
Posted: Wed Feb 03, 2010 4:09 am |
Better than CompactFlash use a microSD card, this is SPI based and is quite fast, also less number of I/Os are used.
You can find drivers for the microSD/ SD card, RS-MMC cards etc the code section of this forum.
The driver for the SD card in the PICC folder also works very well.
thanks
arunb |
