Multiple serial ports on one PIC18F8722
dk-info
PostPosted: Fri Oct 16, 2009 12:45 pm     Reply with quote
I have an application where I need to control five low bandwidth devices using an RS-232 interface.
I haven't tried it, but how many "soft" UARTS can be programmed on a '8722? I only have to access the serial devices every second or so, at a very low bandwidth (1200 Baud).
Is it reasonable to invoke the "#use rs232() five times? What are the resource consequences?
David
PostPosted: Fri Oct 16, 2009 12:50 pm     Reply with quote
See this recent thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=39583
bkamen
PostPosted: Fri Oct 16, 2009 11:47 pm     Reply with quote
As mentioned in the other thread, multiple software uarts is a no-win situation.
PIC24's come with up to 4 uarts.. then you'd have to add an external 4th.
I hooked an octal uart up to a 18F97J60 recently and got it to work - but it needs a lot of optimization.
A PIC24 would have been better for that too.. the customer wanted to try the 97J60 first though..
It can be done - but it's not pretty. :D
-ben
asmallri
PostPosted: Sun Oct 18, 2009 4:04 am     Reply with quote
I disagree. 5 low speed software UARTS all at a constant baud rate is a walk in the park but not using the #use RS232 mechanism.
5 serial ports at 1200 baud could be implemented using high priority interrupts and a single timer. High priority to leave low priority to other functions.
Regards, Andrew
