I2c + RS232 in pic16f8XX
jelectron
PostPosted: Fri Oct 16, 2009 10:37 am     Reply with quote
Hi:
I write this post because I need your help with use I2C + USART in PIC16F8XX. My application is to store data from RS232 in a EEPROM 24LC256. Once the data is stored, I need after to read from EEPROM and take data from other USART port (for software)
If you can help me, very thank
Best Regards
bkamen
PostPosted: Fri Oct 16, 2009 10:51 am     Reply with quote
So what is your question then?
-Ben
jelectron
PostPosted: Fri Oct 16, 2009 11:23 am     Reply with quote
I need a example of I2C + USART (RS232), where the data is stored in the EEPROM for I2C, because i dont know how make it.
If you can help me very thank
PostPosted: Fri Oct 16, 2009 12:07 pm     Reply with quote
This CCS example file provides a simple interface to the eeprom
by using commands typed into a terminal window on your PC:
c:\program files\picc\examples\ex_extee.c
Edit the following line in this example file:
#include "2416.c"
Change it to:
#include <24256.c>
This is the driver for the 24LC256 eeprom:
c:\program files\picc\drivers\24256.c
