access into a register
giustraman
PostPosted: Mon Oct 12, 2009 2:39 am     Reply with quote
How can i get access into a register/bit??
andyfraser
PostPosted: Mon Oct 12, 2009 3:12 am     Reply with quote
Read the manual !
Or you could look at this thread http://www.ccsinfo.com/forum/viewtopic.php?t=40398
Andy
giustraman
Read, not write..
PostPosted: Mon Oct 12, 2009 3:30 am     Reply with quote
I need to read a bit of a register, for example the bit n°1 of ADCONO register (address: 0x1F)...How can I do it?? Thanks...
andyfraser
Read, not write..
PostPosted: Mon Oct 12, 2009 3:34 am     Reply with quote
Well to me it would seem pretty obvious from the link I sent !
In Ronald's example he writes to a bit using GIE = 1 so to read you can do if ( GIE == 1 ). You need to set up a #byte for ADCON0 and a #bit for the bit you want to read.
Andy
PostPosted: Mon Oct 12, 2009 6:08 am     Reply with quote
Expanding on what andyfraser said, you really should take time to read the manual. See #bit in the pre-processor section of the manual. It shows how to define a register bit reference.
In the link he cited, rnielsen (Ron) provides a great example that would answer your question if you would just take a look.
