I2C Problem with MAX6642 sensor and 16F917
freddayz
PostPosted: Thu Oct 08, 2009 10:13 am     Reply with quote
I am using PIC16F917 with compiler 4.071
I am talking/getting data from MAX6642 Temp Sensor via I2C, I am the Master and Temp Sensor is slave.
I cannot communicate with the device using the following code. What can my problem be?
This is my include stuff:
// Include files
#include "16F917.h"
#device adc=10
#include "LBA_App_Main.h"
// PIC Configuration
#use delay ( clock = 8MHZ, type = internal )
//#use rs232 ( baud=38400, xmit=PIN_B7, rcv=PIN_B5, ERRORS )
#fuses HS         // Crystal Osc (> 4 MHz)
#fuses NOWDT       // No watch Dog Timer
#fuses NOPROTECT   // Code not protected from reading
#fuses NOPUT      // No Power Up Timer
#fuses NOBROWNOUT   // No Brownout Reset
#fuses NOIESO      // Internal External Switch Over mode disabled
#fuses FCMEN      // Fail-safe clock monitor enabled,
#fuses NOMCLR      // Master Clear pin used for I/O
//#fuses INTRC_IO
#use i2c ( MASTER, sda = SDA_PIN, scl = SCL_PIN)   // cfg device as master
Header stuff:
// I2C variables
#define MAX6642_I2C_WRITE   0x90      // Address is 1001 000 , the write bit is 0 per I2C standard
#define MAX6642_I2C_READ   0x91      // Address is 1001 000 , the write bit is 1 per I2C standard
#define MAX6642_LOC_TEMP   0x00      // Read local Temperature
#define MAX6642_REM_TEMP   0x01      // Read remote temperature
#define MAX6642_STATUS      0x02      // Read Status Byte
#define MAX6642_CFG_BYTE   0x03      // Read CFG Byte
#define MAX6642_READ_LOC_HL   0x05      // Read Local High Limit
#define MAX6642_READ_REM_HL   0x07      // Read Remote High Limit
#define MAX6642_WRITE_CFG   0x09      // Write CFG Byte
#define MAX6642_WRITE_LOC_HL   0x0B   // Write Local High Limit
#define MAX6642_WRITE_REM_HL   0x0D   // Write Remote High Limit
#define MAX6642_SINGLE_SHOT   0x0F      // Single Shot
#define MAX6642_LOC_TEMP2   0x11      // Read local extended temperature
#define MAX6642_REM_TEMP2   0x10      // Read remote extended temperature
#define MAX6642_DEVID      0xfe      // Read MFG ID
#define MAX6642_TEMP_INVALID   0xff      // Invalide Temperature
PIC Init:
void Process_Initialization ( void )
   // PIC Port Initialization
   setup_lcd(LCD_DISABLED);
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
   Disable_Interrupts(INT_CCP1);
   Disable_Interrupts(INT_CCP2);
   Disable_Interrupts(INT_COMP);
   Disable_Interrupts(INT_COMP2);
   enable_interrupts(INT_SSP);
   // I2C Init
   output_high(SCL_PIN);
   output_high(SDA_PIN);
   delay_us(1000);            // Wait
Temp Sensor CFG:
void TempSensor_Start(void)
   // Set Configuration for Temp Sensor
   i2c_start();
      i2c_write(MAX6642_I2C_WRITE);      // Write to Temp Sensor
      i2c_write(MAX6642_WRITE_CFG);      // Write to CFG Register
   i2c_write(0x00);                 // 0(7) 0(6) 0(5) 0(4) 0(3) 0(2) 0(1) 0(0)
                              // Enables Alerts, Run Mode, Reads both temps, single fault
      i2c_stop();
//   // Set Limits
//   i2c_start();
//      i2c_write(MAX6642_I2C_WRITE);      // Write to Temp Sensor
//      i2c_write(WRITE_REM_HL);      // Write to CFG Register
//   i2c_write(0x00);                 // 0(7) 0(6) 0(5) 0(4) 0(3) 0(2) 0(1) 0(0)
//                              // Enables Alerts, Run Mode, Reads both temps, single fault
//      i2c_stop();
Get Data Function:
void I2C_Messaging(void )
   m_Rem_Temp = 0;
   m_Loc_Temp = 0;
   i2c_start();
      i2c_write(MAX6642_I2C_WRITE);       // insert write address for MAX6642
      i2c_write(MAX6642_REM_TEMP);        // Pointer Byte
   i2c_start();                   // Restart
      i2c_write(MAX6642_I2C_READ);      // Read Address for MAX6642
      Rem_Temp = i2c_read();             // Read from Slave and insert into REM_TEMP
   i2c_start();
      i2c_write(MAX6642_LOC_TEMP);        // Pointer Byte
      Loc_Temp = i2c_read();             // Read from Slave and insert into REM_TEMP
   i2c_stop();
/*   if (Loc_Temp > 0x64)
      m_Loc_Temp = 1;
   if (Rem_Temp > 0x64)
      m_Rem_Temp = 1;
Main
void main ()
   m_Rem_Temp = 0;
   m_Loc_Temp = 0;
   Process_Initialization();
   if(Power_On_Good)                                    //always = 1
      m_PWR_GOOD = 1;
      TempSensor_Start();      //Enable communication on I2C to Temp Sensor
   do
      //do processes here
      I2C_Messaging();
   } while (1);
Thanks in Advance
PostPosted: Thu Oct 08, 2009 12:52 pm     Reply with quote
You are trying to make a driver for the MAX6642.
// I2C Init
Delete all the lines in bold. You don't need to disable the CCP modules
or the interrupts. They are already disabled when the PIC is turned on.
The hardware inside the PIC disables them upon power-on reset.
The exception is that the LCD module is enabled on power-up. CCS
inserts code to disable it, but on some early compiler versions they don't
do it. So it doesn't hurt to disable it, as you have done in your code.
Don't enable INT_SSP interrupts. They are not needed. You don't have
a #int_ssp routine. Don't enable global interrupts. Don't set the SCL
and SDA pins high. They are initialized by the #use i2c() library code.
m_Rem_Temp = 0;
m_Loc_Temp = 0;
i2c_start();
Rem_Temp = i2c_read(0); // Last read must do a NACK
i2c_stop(); // Must do a stop here
i2c_start();
Loc_Temp = i2c_read(0); // Last read must do a NACK
i2c_stop();
Your code to read the registers has some things wrong with it. See the
corrections shown in bold above. Note that a "NACK" is done by giving
the i2c_read() function a parameter of 0, as shown above.
freddayz
PostPosted: Thu Oct 08, 2009 1:21 pm     Reply with quote
Thanks alot for your help....will see if that corrects the problem.
freddayz
PostPosted: Thu Oct 15, 2009 4:34 pm     Reply with quote
That did correct the problem...the other issue I had was with the I2C Slave...it wasn't cfg properly
