ICM7228 8-digit, 7-segment, numeric LED display Driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
jitun
PostPosted: Tue May 12, 2009 3:15 am     Reply with quote
I had used this code in one of my previous project.The code is for interfacing ICM7228 from Intersil(Actually I used this) but if will work fine for the same from Maxim. Thought it will be helpful to someone.
ICM7228.c
#define clk_delay 1
int1 global_mode;
int1 global_ram;
//used to strobe the write pin of ICM7228
//Used as helper function
void pulse_write()
      output_high(ICM_WRITE);
      delay_cycles(clk_delay);
      output_low(ICM_WRITE);
//Takes an array of 8 datas and put them on the digits
//the dp decides the position of the decimal point
//1 -> decimal point on 1st digit
//8 -> decimal point on 8th digit
//mode decides which mode of decoding to use CODE B OR HEX
//0 -> CODE B Decode
//1 -> Hex Decode
//ram decides which RAM  bank to use.
//0 -> RAM bank B
//1 -> RAM bank A
   void display_digits(unsigned int8 arr[],unsigned int8 dp,int1 mode,int1 ram)
      unsigned int8 i;
      int decimal;
      global_mode=mode;
      global_ram=ram;
      if(dp>0 && dp<9)
         decimal=dp-1;
         decimal=-1;
      output_high(ICM_MODE);
      if(mode)
         if(ram)
            ICM_PORT(0xD8);
            ICM_PORT(0xD0);
         if(ram)
            ICM_PORT(0x98);
            ICM_PORT(0x90);
      pulse_write();
      output_low(ICM_MODE);
      //for(i=0;i<8;i++)
      //   arr[i]=data[i];
      for(i=0;i<8;i++)
         if(decimal==i)
            ICM_PORT(arr[i]+0x00);
            ICM_PORT(arr[i]+0x80);
         pulse_write();
      if(mode)
         if(ram)
            ICM_PORT(0x58);
            ICM_PORT(0x50);
         if(ram)
            ICM_PORT(0x18);
            ICM_PORT(0x10);
      pulse_write();
//this is for the no decode mode operation
   void display_digits_nd(unsigned int8 arr[])
      unsigned int8 i;
      ICM_PORT(0xB0);
      pulse_write();
      for(i=0;i<8;i++)
         ICM_PORT(arr[i]^0x80);
         pulse_write();
      ICM_PORT(0x30);
      pulse_write();
//it displays a data at the address given
//1 -> 1st digit
//8 -> 8th digit
//and dis_data is the data that is to be displayed there
//the dp decides whether the decimal point is to be added or not
   void update_single_digit(unsigned int8 addr, unsigned int8 dis_data,int1 dp)
      if(global_mode)
         if(global_ram)
            ICM_PORT(0x58+(addr-1));
            ICM_PORT(0x50+(addr-1));
         if(global_ram)
            ICM_PORT(0x18+(addr-1));
            ICM_PORT(0x10+(addr-1));
      pulse_write();
      if(dp)
          ICM_PORT(dis_data+0x00);
          ICM_PORT(dis_data+0x80);
      pulse_write();
//it displays a data at the address given in no decode mode
//1 -> 1st digit
//8 -> 8th digit
   void update_single_digit_nd(unsigned int8 addr, unsigned int8 data)
      ICM_PORT(0x30+(addr-1));
      pulse_write();
      ICM_PORT(data+0x80);
      pulse_write();
//it toggles the ram bank from A to B and vice versa.
//it is usefull when u need to show two values continously
//without updating the display ram
void toggle_ram()
    if(global_mode)
      if(global_ram)
         ICM_PORT(0x50);
         ICM_PORT(0x88);
      if(global_ram)
         ICM_PORT(0x10);
         ICM_PORT(0x18);
    pulse_write();
    global_ram=~global_ram;
Usage exmaple
main.C
#include <18F4550.h>
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HSPLL                    //High Speed Crystal/Resonator with PLL enabled
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOLVP                      //No Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES MCLR                     //Master Clear pin enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PLL5                     //PLL PreScaler
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
#define ICM_ID7   PIN_D7      //DATA COMING
#define ICM_ID6   PIN_D6      //HEXA/#CODEB
#define ICM_ID5   PIN_D5      //#DECODE
#define ICM_ID4   PIN_D4      //#SHUTDOWN
#define ICM_ID3   PIN_D3      //RAM BANK SELECT
#define ICM_ID2   PIN_D2
#define ICM_ID1   PIN_D1
#define ICM_ID0   PIN_D0
#define ICM_WRITE  PIN_E1
#define ICM_MODE   PIN_E0
#define ICM_PORT(value)   output_d(value)
#include "ICM7228.c"
   int data1[8]={0x38,0x77,0x6F,0x54,0x77,0x1E,0x30,0x78};  //It writes LAgnAJit
   int data2[8]={1,2,3,4,12,11,13,14};
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   display_digits_nd(data1);        //No decode mode
   delay_ms(1500);
   update_single_digit_nd(1,0);     //Clears the 1st position as it is 0 in the no decode mode
   delay_ms(1500);
   display_digits(data2,4,0,0);   //Decode as Code B, Decimal at 4th place
   delay_ms(1500);
   display_digits(data2,2,1,0);   //Decode as Hex, Decimal at 2nd place
   delay_ms(1500);
   update_single_digit(1,6,0);   //Update the 1st digit to '4'
The source code and the Proteus design simulation can be found from the below links
http://rapidshare.com/files/232024658/ICM7228_Interfacing.zip
http://ifile.it/2wd9c6q
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
