Joined: 01 Aug 2007 Posts: 38 Location: AUckland, NEW ZEALAND
PICkit 2 Programmer and PCM Compiler problem
Posted: Thu Feb 12, 2009 3:41 am
First time using the PCM compiler to program PIC16F716. PICkit 2 programs the chip fine but verifying the program comes up with the following message:
Verification of Program Memory failed at address 0x000000
What could i possibly be doing wrong? Any fuses in the code i need? Any help appreciated.
jgschmidt
Joined: 03 Dec 2008 Posts: 184 Location: Gresham, OR USA
Posted: Fri Feb 20, 2009 10:38 am
How are you connecting the PicKit programmer to the 16F716 chip? If you are using the Low Pin Count Demo board, then this is the wrong chip for that board.
I also use the PicKit2 for most of my work but I am using mostly 8/14/20-pin parts. 18-pin parts need to be connected via ICSP.
