FatFs - FAT File System Module - CCS Port
madcat
PostPosted: Tue Dec 30, 2008 11:49 pm     Reply with quote
Hi everyone!
I was wondering if there is a port of FatFs for CCS out there ?
http://elm-chan.org/fsw/ff/00index_e.html
I'm trying to use FAT for MMC cards and nothing seems to work (direct spi R/W is ok). Found this library and it looks well written and promising.
They have an example for PIC but it does not look like CCS.
It looks like not too difficult task so I've tried to do it myself but having some compilation errors i can't figure out. Is there somth ready or can someone help me please ?
crystal_lattice
PostPosted: Wed Dec 31, 2008 3:20 am     Reply with quote
Hi, I've tried the same thing, but with my limited programming knowledge I did not suceed. The lib does look very promising indeed and would make a very nice addition to the CCS code lib if a few good programmers teamed up and took the time to convert it.
Brush electronics sells a CCS port of the code but unfortunately it is based on a rather old version of the FS and since then some very nice additions has been made to the original ELM Chan code.
If you are seriously wanting to convert the new version to CCS I could share my attempts with you. It would be nice though to get some more programmers involved but unfortunately everybody wants a FAT FS but nobody seems to want to put the effort in to help make one work with CCS...
madcat
PostPosted: Wed Dec 31, 2008 9:10 am     Reply with quote
Actually i was surprised no one did it so far. And with all the
Initially i thought that it wont be too hard. It is written in ANSI C. The low level MMC access library from CCS works fine. So i thought i just have to link both... But i haven't even reached that point. It does not compile at all :(
I've modified the integer.h but they used some CCS keywords as BYTE CHAR etc... looks like making CCS case sensitive by adding #CASE solves some of these... but then i get many more errors i don't know how to fix...
My programming knowledge is limited but i'm still under impression that it should not be a big problem to someone who has a better knowledge.
But looks like all the programmers are celebrating the new year now Laughing
dyeatman
PostPosted: Wed Dec 31, 2008 10:11 am     Reply with quote
According to an email I got from CCS a little while back they are working to make version 4.100 compile the Microchip TCP/IP stack code with no modifications. Overall there seems to be a lot of new things coming in version 4.100 Hopefully, with those changes, porting C18 and ANSI code to CCS will be much easier
asmallri
PostPosted: Wed Dec 31, 2008 12:54 pm     Reply with quote
What feature specifically are you looking for? The initial port was based on an earlier code base but since then I have enhanced the software providing functions not included in the original ELM code.
The new ELM software does support multiple SD cards to be used simultaneously I have no plan to support this because I do not think it is a useful feature with PICs with limited RAM.
Regards, Andrew
madcat
PostPosted: Wed Dec 31, 2008 2:00 pm     Reply with quote
Hi, Andrew
My project is for educational and non commerical use, so paid software is not an option for me.
For such use It would be nice to have a free open source version....
asmallri
PostPosted: Wed Dec 31, 2008 3:56 pm     Reply with quote
madcat wrote:
Hi, Andrew
No problem. Several of my customers have been university students doing final year projects as well as university departments. They treat the software the same way they treat buying hardware components.
Regards, Andrew
crystal_lattice
PostPosted: Thu Jan 01, 2009 11:20 am     Reply with quote
they are working to make version 4.100 compile the Microchip TCP/IP stack code with no modifications.... porting C18 and ANSI code to CCS will be much easier...
This sounds very promising, will have to wait and see if the improvements are aimed at TCP/IP Stack specifically or a broader ANSI compatibility.
I've somewhat solved the integer.h problems but am not familiar with the 'higher/complex' syntax used in some of the code which makes it very hard to understand and ultimately convert. Unfortunately i do not know anybody with expert knowledge/interest of/in ANSI C AND CCS C to ask for advice.
We will have to see if we can get PCM Programmer and others involved...
...or if CCS will move towards ANSI C compatibility...
asmallri
PostPosted: Sat Jan 03, 2009 10:49 am     Reply with quote
[quote="crystal_lattice"]
Anyone that has used PCD and C30 will realize that this "goal" is a long way from reality. There is not a snow balls chance in hell of PCD compiling Microchips TCP/IP stack without significant modifications.
Regards, Andrew
raiderbg
PostPosted: Thu Jun 28, 2012 2:23 am     Reply with quote
Hello everyone,
I successfully compile the FatFs R0.09 under CCS!
Now I doing the hardest work, to make it work Very Happy
Tom-H-PIC
PostPosted: Fri Jul 27, 2012 8:25 pm     Reply with quote
Hello
raiderbg did you get the FatFs to work?
If so would you please share?
Thanks Tom
