is it possible to read the program memory size into a variable? 18F2620 has 64k, so the value that must be read is 0xFFFF into an int16 variable. I need the size for a further process and the function I have to write should be applicable for different PICs with different program memory space.
Thanks for any help!
Best Regards
nilsener
Posted: Mon Oct 06, 2008 9:49 am
Not 'read', but it is available as a defined value for you.
getenv("PROGRAM_MEMORY")
will return the size of the program memory for the current processor.
