I´ve successfully tested "Flex_LCD" code with an 16F767 device and a 16x2 LCD display. Now my problem is that other than text, I need to show data coming from variables, let´s say the value collected at an analog input or the number of events accumulated by a counter...
Any suggestions to do this?
Posted: Mon Sep 29, 2008 6:58 pm
Look in the CCS manual at the section on printf. Look at the format
strings that are used to display each variable data type. Here is a
code example of how to display a floating point variable on the LCD:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168
ricperez
It worked great!
Posted: Sat Oct 04, 2008 10:15 pm
Thanks for your input PCM Programmer. I´ve followed the example you suggested and it is now working.
Keep up with the good work.
