davidbue
Playback of 1 bit encoded wav and mp3 files. |
Posted: Wed Jun 11, 2008 7:20 am |
Hi everybody.
I just wanted to share with you how I got a PIC18F2220 to play back 1 bit encoded sound files using the BTc Sound Encoder 2.0 Software from www.romanblack.com
http://www.romanblack.com/picsound.htm
I hope you'll find my code useful, and I'd appreciate any feedback that I can use to improve the code.
#include "C:\soundgen\take1.h" //Standard, nobrainer header
const char sound_data[] =
//Some encoded sound. This is only a few microseconds, but you'll get the idea.
0x12,0x5e,0xaa,0xaa,0xca,0xaa,0xaa,0xb2,
0xaa,0xa5,0x66,0xcd,0x2a,0xcc,0xcc,0x9a
int8 i;
int8 c;
int8 currentbit;
c = sound_data[i];
setup_oscillator(OSC_8MHZ|OSC_INTRC);
setup_adc_ports(AN0_TO_AN1|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
for (i=0; i<17; i++){ //Go through the sound_data array
c = sound_data[i];
//***********************Read bitwise
for (currentbit = 0; currentbit < 8; currentbit++){
if( bit_test(c,currentbit) ){ //If the bit is a 1.
output_high(pin_b5);
}else{ //If the bit is a 0.
output_low(pin_b5);
delay_us(4);
//**********************/Read bitwise
// Play a tone after playback of the encoded audio file.
while(1){
delay_ms(1);
output_low(pin_b5);
delay_ms(1);
That's it.
Best regards
David |
ratgod
Joined: 27 Jan 2006 Posts: 69 Location: Manchester, England
Posted: Sun Sep 07, 2008 9:15 am |
do you know how to include and play any of the exported files from the BTc Sound encoder from within the PIC?
or rather how could I #include the MikroC file and have that played using your routine? or do you have a converter? |
ratgod
Posted: Sun Sep 07, 2008 9:47 pm |
please ignore my last reply, I have created a small program to convert the MikroC C files that are exported from BTc to C file that you can just #include into your code
http://home.cogeco.ca/~ratgod/BTC2CCS.exe
note: I accept no responsibility for damage cause by misuse of this software, its provided as is.
I've just scanned it with AVG and its clean.
The software converts the layout of the data to the same form as in the example, but it also counts the bytes and makes a define for them.
The software is easy to use, once loaded, you click Select File, then you choose a C file exported from BTc, then click on convert, this will then ask you the destination filename, name this whatever you like, then when the conversion is complete, put the file with you main source code and #include it.
In the example code from davidbue, a line states:
Code: | for (i=0; i<17; i++){ //Go through the sound_data array |
I have replaced it with this, so the included file sets the length:
Code: | for (i=0; i<sound_length; i++){ //Go through the sound_data array |
I have had a couple of the test files from BTc playing through it.
I'm using a PIC18F2520 with a 20MHz crystal, I'm not sure how to set it to run of the internal 8MHz like yours is set up, any ideas? |
acidice333
Posted: Mon Sep 07, 2009 3:05 pm |
Does anything need to change when running at 48mhz? |
SherpaDoug
How to import BTc sound data into CCS? |
Posted: Sun Aug 22, 2010 12:10 pm |
Does anyone have a good way to import sound files such as those created by Roman Black's BTc 1 bit Sound Encoder into a CCS program? Roman show an example with 16 sound samples, but I need to use a few hundred samples.
The link in this 2 year old reply is broken.
_________________ The search for better is endless. Instead simply find very good and get the job done. |
Jeff King
Joined: 20 Oct 2003 Posts: 43 Location: Hillsdale, Michigan USA
Re: How to import BTc sound data into CCS? |
Posted: Wed Jun 15, 2011 2:04 pm |
SherpaDoug wrote: |
Does anyone have a copy they might be willing to share of the above file? E-mail to king.robert.j@gmail.com if you do and thanks. |
