How to use #ORG with function declearation?
Simon
PostPosted: Wed Jul 23, 2003 11:52 am     Reply with quote
For example, if I want to place a function in 0x0800, 0x09FF, I do this:
#ORG 0x0800, 0x09FF
void foo() {
void bar() {
but if I want to declear this function on top, what should I do?
void foo(); --- don't work,
void bar();
Compiler will issue error that different difinition on foo
#ORG 0x0800, 0x09FF
void foo();
void bar(); --- don't work,
Compiler will issue error that different difinition on bar
What should I do? Please help, thank you!
Simon
___________________________
Original Post ID: 144516290
Re: How to use #ORG with function declearation?
PostPosted: Wed Jul 23, 2003 11:59 am     Reply with quote
To use #org with function prototypes, you must declare the
prototype as #separate. Example:
#include "c:\Program Files\Picc\Devices\16F877A.H"
#use delay(clock = 8000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
#separate
my_func();
my_func();
#org 0x400, 0x500
my_func()
char i;
i = 5;
Original Post ID: 144516291
