		| Author | Message |
		| Simon Guest
				| How to use #ORG with function declearation? |
				|  Posted: Wed Jul 23, 2003 11:52 am |   |
				| Hi,
 For example, if I want to place a function in 0x0800, 0x09FF, I do this:
 #ORG 0x0800, 0x09FF
 void foo() {
 void bar() {
 but if I want to declear this function on top, what should I do?
 void foo();   --- don't work,
 void bar();
 Compiler will issue error that different difinition on foo
 #ORG 0x0800, 0x09FF
 void foo();
 void bar();   --- don't work,
 Compiler will issue error that different difinition on bar
 What should I do? Please help, thank you!
 Simon
 ___________________________
 Original Post ID: 144516290
		| PCM programmer
				| Re: How to use #ORG with function declearation? |
				|  Posted: Wed Jul 23, 2003 11:59 am |   |
				| To use #org with function prototypes, you must declare the prototype as #separate.  Example:
 #include "c:\Program Files\Picc\Devices\16F877A.H"
 #use delay(clock = 8000000)
 #use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
 #separate
 my_func();
 my_func();
 #org 0x400, 0x500
 my_func()
 char i;
 i = 5;
 Original Post ID: 144516291
 | You cannot post new topics in this forum You cannot reply to topics in this forum
