tenebris
Comparator 16F628A not working |
Posted: Thu Mar 15, 2018 8:51 am |
Hello! I'm using the 5.07v compiler, and trying to make C2OUT work with the argument NC_NC_A1_A2 but nothing happens...
#include <16f628a.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOMCLR, NOBROWNOUT, PUT, NOLVP
setup_comparator (NC_NC_A1_A2);
while(TRUE){
if (C2OUT)
output_high(PIN_A5);
output_low(PIN_A5);
And this is what the .lst looks like:
.................... setup_comparator (NC_NC_A1_A2);
000D: MOVLW 05
000E: MOVWF 1F
000F: BSF 03.5
0010: MOVF 05,W
0011: IORLW 06
0012: MOVWF 05
0013: MOVLW 03
0014: MOVWF 77
0015: DECFSZ 77,F
0016: GOTO 015
0017: BCF 03.5
0018: MOVF 1F,W
0019: BCF 0C.6
I know this is a very simple problem, but I can't figure whats going wrong. The circuit is: Pot 10K on A2, LDR on A1, and a led on A5
Nothing happens in Proteus, too...
_________________ */ |
Joined: 01 Jul 2010 Posts: 9186 Location: Greensville,Ontario
Posted: Thu Mar 15, 2018 2:12 pm |
or look at the pinout diagrams...
they clearly show with arrows possible data directions.. |
tenebris
Posted: Thu Mar 15, 2018 8:35 pm |
thank you all _________________ */ |
