Comparator 16F628A not working
tenebris
PostPosted: Thu Mar 15, 2018 8:51 am     Reply with quote
Hello! I'm using the 5.07v compiler, and trying to make C2OUT work with the argument NC_NC_A1_A2 but nothing happens...
#include <16f628a.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOMCLR, NOBROWNOUT, PUT, NOLVP
setup_comparator (NC_NC_A1_A2);
   while(TRUE){
      if (C2OUT)
      output_high(PIN_A5);
      output_low(PIN_A5);
And this is what the .lst looks like:
.................... setup_comparator (NC_NC_A1_A2);
000D:  MOVLW  05
000E:  MOVWF  1F
000F:  BSF    03.5
0010:  MOVF   05,W
0011:  IORLW  06
0012:  MOVWF  05
0013:  MOVLW  03
0014:  MOVWF  77
0015:  DECFSZ 77,F
0016:  GOTO   015
0017:  BCF    03.5
0018:  MOVF   1F,W
0019:  BCF    0C.6
I know this is a very simple problem, but I can't figure whats going wrong. The circuit is: Pot 10K on A2, LDR on A1, and a led on A5
Nothing happens in Proteus, too...
PostPosted: Thu Mar 15, 2018 10:59 am     Reply with quote
Look at this table in the 16F628A data sheet, on page 13:
TABLE 3-2: PIC16F627A/628A/648A PINOUT DESCRIPTION
What does it list in the "Output Type" column for RA5 ?
Data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/40044G.pdf
PostPosted: Thu Mar 15, 2018 2:12 pm     Reply with quote
or look at the pinout diagrams...
they clearly show with arrows possible data directions..
tenebris
PostPosted: Thu Mar 15, 2018 8:35 pm     Reply with quote
thank you all
