rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
| Stucture initialization doesn't work for strings [SOLVED] |
Posted: Mon Dec 21, 2015 1:16 pm |
Compiler: 5.025
This what I found.
typedef struct
char* pc;
}cs;
cs cs_t= {"RIKO"};
//In main
printf("%s\n", cs_t.pc); |
Guess what, I get only new line character on the terminal. This compiler is a mess. _________________ A person who never made a mistake never tried anything new.
Posted: Mon Dec 21, 2015 2:24 pm |
It's your compiler version. It's too old. I compiled the following test
program with CCS vs. 5.051 and ran it in MPLAB simulator (MPLAB v8.92)
and it ran fine. It displays the following in the Output window:
If possible, you should upgrade your compiler.
Test program:
#include <18F4620.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
typedef struct
char* pc;
}cs;
cs cs_t= {"RIKO"};
while(TRUE);
rikotech8
Posted: Tue Dec 22, 2015 2:59 am |
Yes you are right. I upgraded up to version 5.051 and it works now. _________________ A person who never made a mistake never tried anything new. |
