Stucture initialization doesn't work for strings [SOLVED]
rikotech8
PostPosted: Mon Dec 21, 2015 1:16 pm     Reply with quote
Compiler: 5.025
This what I found.
typedef struct
   char* pc;
}cs;
cs cs_t= {"RIKO"};
//In main
printf("%s\n", cs_t.pc);
Guess what, I get only new line character on the terminal. This compiler is a mess.
A person who never made a mistake never tried anything new.
PostPosted: Mon Dec 21, 2015 2:24 pm     Reply with quote
It's your compiler version. It's too old. I compiled the following test
program with CCS vs. 5.051 and ran it in MPLAB simulator (MPLAB v8.92)
and it ran fine. It displays the following in the Output window:
RIKO
If possible, you should upgrade your compiler.
Test program:
#include <18F4620.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
typedef struct
   char* pc;
}cs;
cs cs_t= {"RIKO"};
while(TRUE);
rikotech8
PostPosted: Tue Dec 22, 2015 2:59 am     Reply with quote
Yes you are right. I upgraded up to version 5.051 and it works now.
