Am I missing something?
ghamblin
PostPosted: Sat Nov 21, 2015 12:34 pm     Reply with quote
I'm getting the error "Expecting function name ::" at each line that contains a printf() statement. Here is a code snippet:
if(!input(PIN_A0))
    x=9;
    while(!input(PIN_A0) && x)
        printf(lcd_putc,"Pending\nReset");
        lcd_gotoxy(8,2);
        printf(lcd_putc,"%d",x--);
    if(!x)
        WRITE_LONG_EEPROM(0, (int32)0);
        lcd_putc('\f');
        printf(lcd_putc,"Reset\n PWR OFF");
If I comment out the printf() lines it compiles without error. I figure I must be missing something here, and perhaps another set of eyes will see it?
Thanks,
Glenn
-Glenn
PostPosted: Sat Nov 21, 2015 1:00 pm     Reply with quote
With no more than you have given us I randomly picked a short section of
test code I had and dropped yours into it. It compiled it under 5.051 with no
problems. It may be something further upstream.
What chip?
What compiler version?
ghamblin
PostPosted: Sat Nov 21, 2015 1:13 pm     Reply with quote
PCM Compiler Version 5.051 (Linux command line version)
Here's the .err file content:
*** Error 53 "CashMeterMX.c" Line 57(29,30): Expecting function name ::
*** Error 53 "CashMeterMX.c" Line 77(121,125): Expecting function name ::
2 Errors, 0 Warnings.
Build Failed.
Here's the whole program:
 * File:   CashMeterMX.c
 * Author: Glenn Hamblin
 * Mexico Version of CashMeter
 * Created on February 15, 2014, 7:18 PM
#include <16F1823.h>
#device WRITE_EEPROM = NOINT
#fuses PUT,NOWDT,INTRC_IO,NOMCLR,NOCLKOUT,NOIESO,NOLVP,NOPROTECT,NODEBUG
#USE STANDARD_IO(a)
#USE STANDARD_IO(c)
#use delay(clock=8M)
#include <stdio.h>
#include <stdlib.h>
#include <CashMeterMX.h>
#include <gh_lcd.c>
int main(void)
int8 nickels=0,x;
CASH=0;
TICKS=TICKS_PER_SECOND;
set_rtcc(0);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);/*increments every 128us
                                                   //and overflows every 32.7ms*/
setup_oscillator(OSC_8MHZ | OSC_NORMAL | OSC_PLL_OFF);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_ccp1(CCP_OFF);
set_timer1(0);
port_a_pullups(3);
delay_ms(50);
delay_ms(50);
lcd_putc('\f');
if(!input(PIN_A0))
    x=9;
        lcd_gotoxy(8,2);
    if(!x)
        lcd_putc('\f');
lcd_putc('\f');
delay_ms(10);
CASH=READ_LONG_EEPROM(0);
LASTCASH=CASH;
printf(lcd_putc,"CASH MX \n%8.1w",CASH);
set_timer1(0);
    update_time();
    if(!input(PIN_A5))
        delay_ms(2);
        while(!input(PIN_A5));
        delay_ms(2);
        nickels=get_timer1();
        set_timer1(0);
    if(nickels >0)
        CASH=CASH+(nickels*5);
        nickels=0;
    if(LASTCASH != CASH)
        LASTCASH=CASH;
        if(CASH > (int32)9999999)
            lcd_gotoxy(8,1);
            lcd_putc('#');
            CASH=0;
        lcd_gotoxy(1,2);
        printf(lcd_putc,"%8.1w",CASH);
        MINUTES=0;
        SECONDS=0;
if(MINUTES > 4)
    MINUTES=0;
    SECONDS=0;
    if(READ_LONG_EEPROM(0) != CASH)
        WRITE_LONG_EEPROM(0,CASH);
        lcd_gotoxy(5,1);
        lcd_putc(' ');
    lcd_gotoxy(5,1);
    lcd_putc('*');
    return (0);
-Glenn
drolleman
PostPosted: Sat Nov 21, 2015 1:19 pm     Reply with quote
lcd_putc needs to go somewhere
lcd_putc(char buffer)
// put charter somewhere
if you have something like this, you may be missing the prototype for this funtion
ghamblin
PostPosted: Sat Nov 21, 2015 1:48 pm     Reply with quote
I have lcd_putc() defined in gh_lcd.c. It's just a modification of the original CCS file lcd.c that I've been using for years.
As a test, I built this little program:
 * File:   newmain.c
 * Author: glenn
 * Created on November 21, 2015, 12:21 PM
#USE STANDARD_IO(a)
#USE STANDARD_IO(c)
#include <stdio.h>
#include <stdlib.h>
#include <lcd.c>
int main(void)
    printf(lcd_putc,"Hello") ;
And it generated these errors:
*** Error 28 "/opt/picc/drivers/lcd.c" Line 163(4,5): Expecting an identifier Bad SFR name
*** Error 12 "/opt/picc/drivers/lcd.c" Line 163(5,9): Undefined identifier
*** Error 48 "/opt/picc/drivers/lcd.c" Line 163(10,16): Expecting a (
*** Error 28 "/opt/picc/drivers/lcd.c" Line 164(4,5): Expecting an identifier Bad SFR name
*** Error 48 "/opt/picc/drivers/lcd.c" Line 164(5,9): Expecting a (
*** Error 48 "/opt/picc/drivers/lcd.c" Line 164(10,17): Expecting a (
*** Error 28 "/opt/picc/drivers/lcd.c" Line 164(33,34): Expecting an identifier Bad SFR name
*** Error 48 "/opt/picc/drivers/lcd.c" Line 164(33,34): Expecting a (
*** Error 43 "/opt/picc/drivers/lcd.c" Line 164(34,38): Expecting a declaration
9 Errors, 0 Warnings.
Build Failed.
So something is amiss. Can you compile this little program?
-Glenn
PostPosted: Sat Nov 21, 2015 1:51 pm     Reply with quote
You are missing some defines that must be before lcd.c
Look at the comments in the lcd.c file for info.
//// To use port access, #define LCD_DATA_PORT to the SFR location of ////
//// of the GPIO port that holds the interface, -AND- edit LCD_PIN_MAP ////
//// of this file to configure the pin order. If you are using a ////
//// baseline PIC (PCB), then LCD_OUTPUT_MAP and LCD_INPUT_MAP also must ////
//// be defined.
ghamblin
PostPosted: Sat Nov 21, 2015 2:02 pm     Reply with quote
Ah, yes. That info is in my header file. I forgot to put it in my simple program.
I added this, and it still fails, same errors. I don't understand why it used to compile OK, but now gives this weird error.
 * File:   newmain.c
 * Author: glenn
#USE STANDARD_IO(a)
#USE STANDARD_IO(c)
#include <stdio.h>
#include <stdlib.h>
#include <lcd.c>
#define LCD_DATA_PORT      getenv("SFR:PORTC")
#define LCD_ENABLE_PIN  PIN_A2
#define LCD_RS_PIN      PIN_C4
#define LCD_RW_PIN      PIN_C5
#define LCD_DATA4       PIN_C0
#define LCD_DATA5       PIN_C1
#define LCD_DATA6       PIN_C2
#define LCD_DATA7       PIN_C3
#define LCD_LINE_LENGTH 8
int main(void)
[quote]
[/quote]
-Glenn
PostPosted: Sat Nov 21, 2015 2:03 pm     Reply with quote
The defines must be BEFORE LCD.C...
ghamblin
PostPosted: Sat Nov 21, 2015 2:11 pm     Reply with quote
Duh! Thanks.
OK, That compiles fine. So I'm back to my original problem.
-Glenn
PostPosted: Sat Nov 21, 2015 2:13 pm     Reply with quote
I would first go back and add the defines prior to your gh_lcd.c include...
ghamblin
PostPosted: Sat Nov 21, 2015 2:14 pm     Reply with quote
Strike that. I just reopened my original file, and it compiled error free.
So that was a time sink I guess.
Thank you for looking, I appreciate it.
Glenn
-Glenn
