ghamblin
Am I missing something? |
Posted: Sat Nov 21, 2015 12:34 pm |
I'm getting the error "Expecting function name ::" at each line that contains a printf() statement. Here is a code snippet:
if(!input(PIN_A0))
x=9;
while(!input(PIN_A0) && x)
printf(lcd_putc,"Pending\nReset");
lcd_gotoxy(8,2);
printf(lcd_putc,"%d",x--);
if(!x)
WRITE_LONG_EEPROM(0, (int32)0);
lcd_putc('\f');
printf(lcd_putc,"Reset\n PWR OFF");
If I comment out the printf() lines it compiles without error. I figure I must be missing something here, and perhaps another set of eyes will see it?
Thanks,
Glenn _________________ -Glenn |
Posted: Sat Nov 21, 2015 1:00 pm |
With no more than you have given us I randomly picked a short section of
test code I had and dropped yours into it. It compiled it under 5.051 with no
problems. It may be something further upstream.
What chip?
What compiler version? _________________ Google and Forum Search are some of your best tools!!!! |
ghamblin
Posted: Sat Nov 21, 2015 1:13 pm |
PCM Compiler Version 5.051 (Linux command line version)
Here's the .err file content:
*** Error 53 "CashMeterMX.c" Line 57(29,30): Expecting function name ::
*** Error 53 "CashMeterMX.c" Line 77(121,125): Expecting function name ::
2 Errors, 0 Warnings.
Build Failed.
Here's the whole program:
* File: CashMeterMX.c
* Author: Glenn Hamblin
* Mexico Version of CashMeter
* Created on February 15, 2014, 7:18 PM
#include <16F1823.h>
#device WRITE_EEPROM = NOINT
#fuses PUT,NOWDT,INTRC_IO,NOMCLR,NOCLKOUT,NOIESO,NOLVP,NOPROTECT,NODEBUG
#USE STANDARD_IO(a)
#USE STANDARD_IO(c)
#use delay(clock=8M)
#include <stdio.h>
#include <stdlib.h>
#include <CashMeterMX.h>
#include <gh_lcd.c>
int main(void)
int8 nickels=0,x;
CASH=0;
TICKS=TICKS_PER_SECOND;
set_rtcc(0);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);/*increments every 128us
//and overflows every 32.7ms*/
setup_oscillator(OSC_8MHZ | OSC_NORMAL | OSC_PLL_OFF);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_ccp1(CCP_OFF);
set_timer1(0);
port_a_pullups(3);
delay_ms(50);
delay_ms(50);
lcd_putc('\f');
if(!input(PIN_A0))
x=9;
lcd_gotoxy(8,2);
if(!x)
lcd_putc('\f');
lcd_putc('\f');
delay_ms(10);
CASH=READ_LONG_EEPROM(0);
LASTCASH=CASH;
printf(lcd_putc,"CASH MX \n%8.1w",CASH);
set_timer1(0);
update_time();
if(!input(PIN_A5))
delay_ms(2);
while(!input(PIN_A5));
delay_ms(2);
nickels=get_timer1();
set_timer1(0);
if(nickels >0)
CASH=CASH+(nickels*5);
nickels=0;
if(LASTCASH != CASH)
LASTCASH=CASH;
if(CASH > (int32)9999999)
lcd_gotoxy(8,1);
lcd_putc('#');
CASH=0;
lcd_gotoxy(1,2);
printf(lcd_putc,"%8.1w",CASH);
MINUTES=0;
SECONDS=0;
if(MINUTES > 4)
MINUTES=0;
SECONDS=0;
if(READ_LONG_EEPROM(0) != CASH)
WRITE_LONG_EEPROM(0,CASH);
lcd_gotoxy(5,1);
lcd_putc(' ');
lcd_gotoxy(5,1);
lcd_putc('*');
return (0);
drolleman
Posted: Sat Nov 21, 2015 1:19 pm |
lcd_putc needs to go somewhere
lcd_putc(char buffer)
// put charter somewhere
if you have something like this, you may be missing the prototype for this funtion |
ghamblin
Posted: Sat Nov 21, 2015 1:48 pm |
I have lcd_putc() defined in gh_lcd.c. It's just a modification of the original CCS file lcd.c that I've been using for years.
As a test, I built this little program:
* File: newmain.c
* Author: glenn
* Created on November 21, 2015, 12:21 PM
#USE STANDARD_IO(a)
#USE STANDARD_IO(c)
#include <stdio.h>
#include <stdlib.h>
#include <lcd.c>
int main(void)
printf(lcd_putc,"Hello") ;
And it generated these errors:
*** Error 28 "/opt/picc/drivers/lcd.c" Line 163(4,5): Expecting an identifier Bad SFR name
*** Error 12 "/opt/picc/drivers/lcd.c" Line 163(5,9): Undefined identifier
*** Error 48 "/opt/picc/drivers/lcd.c" Line 163(10,16): Expecting a (
*** Error 28 "/opt/picc/drivers/lcd.c" Line 164(4,5): Expecting an identifier Bad SFR name
*** Error 48 "/opt/picc/drivers/lcd.c" Line 164(5,9): Expecting a (
*** Error 48 "/opt/picc/drivers/lcd.c" Line 164(10,17): Expecting a (
*** Error 28 "/opt/picc/drivers/lcd.c" Line 164(33,34): Expecting an identifier Bad SFR name
*** Error 48 "/opt/picc/drivers/lcd.c" Line 164(33,34): Expecting a (
*** Error 43 "/opt/picc/drivers/lcd.c" Line 164(34,38): Expecting a declaration
9 Errors, 0 Warnings.
Build Failed.
So something is amiss. Can you compile this little program? _________________ -Glenn |
Posted: Sat Nov 21, 2015 1:51 pm |
You are missing some defines that must be before lcd.c
Look at the comments in the lcd.c file for info.
Quote: | //// To use port access, #define LCD_DATA_PORT to the SFR location of ////
//// of the GPIO port that holds the interface, -AND- edit LCD_PIN_MAP ////
//// of this file to configure the pin order. If you are using a ////
//// baseline PIC (PCB), then LCD_OUTPUT_MAP and LCD_INPUT_MAP also must ////
//// be defined. |
ghamblin
Posted: Sat Nov 21, 2015 2:02 pm |
Ah, yes. That info is in my header file. I forgot to put it in my simple program.
I added this, and it still fails, same errors. I don't understand why it used to compile OK, but now gives this weird error.
* File: newmain.c
* Author: glenn
#USE STANDARD_IO(a)
#USE STANDARD_IO(c)
#include <stdio.h>
#include <stdlib.h>
#include <lcd.c>
#define LCD_DATA_PORT getenv("SFR:PORTC")
#define LCD_ENABLE_PIN PIN_A2
#define LCD_RS_PIN PIN_C4
#define LCD_RW_PIN PIN_C5
#define LCD_DATA4 PIN_C0
#define LCD_DATA5 PIN_C1
#define LCD_DATA6 PIN_C2
#define LCD_DATA7 PIN_C3
#define LCD_LINE_LENGTH 8
int main(void)
[quote]
[/quote] |
Posted: Sat Nov 21, 2015 2:03 pm |
The defines must be BEFORE LCD.C... _________________ Google and Forum Search are some of your best tools!!!! |
ghamblin
Posted: Sat Nov 21, 2015 2:11 pm |
Duh! Thanks.
OK, That compiles fine. So I'm back to my original problem. _________________ -Glenn |
Posted: Sat Nov 21, 2015 2:13 pm |
I would first go back and add the defines prior to your gh_lcd.c include... _________________ Google and Forum Search are some of your best tools!!!! |
ghamblin
Posted: Sat Nov 21, 2015 2:14 pm |
Strike that. I just reopened my original file, and it compiled error free.
So that was a time sink I guess.
Thank you for looking, I appreciate it.
