ADC problem
art
ADC problem
PostPosted: Tue Sep 15, 2015 1:28 am     Reply with quote
Hi, i'm having trouble with ADC. Suppose when i used pic18f4550 it can be used for 10 bit ADC. But it only display 8bit. What is wrong with my code?
#include <18F4550.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,error)
   int i;
   float min, value, max;
    setup_port_a(ALL_ANALOG);
    set_adc_channel(0);
    do  {
            min=1023;
            max=0;
            for(i=0; i<=1; ++i)
                  delay_ms(5);
                  value = Read_ADC();
                   If( value<=min);
                       min=value*5/1023;
                   If( value>=min);
                       max=value;
             printf(" Voltage : %2.3f V   NO: %3.0f ", min, max);
            }while(TRUE);
PostPosted: Tue Sep 15, 2015 1:45 am     Reply with quote
Download the CCS manual for your compiler:
Look in the section called "ADC". It's on page 48 in the Adobe reader.
(numbered page 38).
It says:
#DEVICE ADC=xx
Configures the read_adc return size. For example, using a PIC with a
10 bit A/D you can use 8 or 10 for xx- 8 will return the most significant
byte, 10 will return the full A/D reading of 10 bits.
The default is 8 bits. So you need to put in a #device statement right
after the #include for your PIC.
Also, this is going to fail to compile:
Consult the CCS manual and fix it.
art
PostPosted: Tue Sep 15, 2015 1:51 am     Reply with quote
Thank you very much, problem solve. Very Happy
