art
| ADC problem |
Posted: Tue Sep 15, 2015 1:28 am |
Hi, i'm having trouble with ADC. Suppose when i used pic18f4550 it can be used for 10 bit ADC. But it only display 8bit. What is wrong with my code?
| Code: | #include <18F4550.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,error)
int i;
float min, value, max;
setup_port_a(ALL_ANALOG);
set_adc_channel(0);
do {
min=1023;
max=0;
for(i=0; i<=1; ++i)
delay_ms(5);
value = Read_ADC();
If( value<=min);
min=value*5/1023;
If( value>=min);
max=value;
printf(" Voltage : %2.3f V NO: %3.0f ", min, max);
}while(TRUE);
Posted: Tue Sep 15, 2015 1:45 am |
Download the CCS manual for your compiler:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look in the section called "ADC". It's on page 48 in the Adobe reader.
(numbered page 38).
It says:
| Quote: |
#DEVICE ADC=xx
Configures the read_adc return size. For example, using a PIC with a
10 bit A/D you can use 8 or 10 for xx- 8 will return the most significant
byte, 10 will return the full A/D reading of 10 bits.
The default is 8 bits. So you need to put in a #device statement right
after the #include for your PIC.
Also, this is going to fail to compile:
| Quote: | | #use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,error) |
Consult the CCS manual and fix it. |
art
Posted: Tue Sep 15, 2015 1:51 am |
Thank you very much, problem solve.  |
