overmindx
timer1 and 18f67k22 |
Posted: Mon Aug 11, 2014 1:37 am |
hi,
how come this code doesnt work?
#include <18F67K22.h>
#device adc=12
#device PASS_STRINGS = IN_RAM
#FUSES WDT_SW, WDT32768, INTRC_IO, NOPROTECT, NOIESO, BROWNOUT, PUT, NOCPD, STVREN, NODEBUG, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, NOXINST, MCLR, RTCOSC_T1
#use delay(clock=16000000)
#use rs232(force_sw,baud=57600, xmit=PIN_G1, rcv=PIN_G2, stream=PC)
#Byte TMR1H = 0xFCF
#Byte T1CON = 0xFCD
int1 TESTFLAG=0;
#int_TIMER1
void TIMER1_isr()
bit_clear(T1CON,1);
bit_set(TMR1H,7);
bit_set(T1CON,1);
TESTFLAG=TRUE;
delay_ms(2000);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_ENABLE_SOSC);
do{
fprintf(PC,"TESTFLAG=%i\r",TESTFLAG);
}while(1);
this code just outputs TESTFLAG=0.
my compiler version is 5.26. when i used a lower compiler version, this code works. please help.
thanks. |
Posted: Mon Aug 11, 2014 3:15 am |
What version 'earlier compiler'?. |
overmindx
Posted: Mon Aug 11, 2014 3:58 am |
if i used v.4.114 it outputs TESTFLAG=1 |
asmallri
Posted: Mon Aug 11, 2014 6:32 am |
overmindx wrote: | if i used v.4.114 it outputs TESTFLAG=1 |
In traditional C TESTFLAG should be declared volatile _________________ Regards, Andrew
overmindx
Posted: Mon Aug 11, 2014 7:48 am |
hi,
i followed your suggestion by declaring TEST_FLAG as volatile but it still doesnt solve the problem. It seems for some reason isnt triggering the interrupt. |
Posted: Mon Aug 11, 2014 8:44 am |
Odd.
I had already tried in 4.141, and this develops identical code setting up the timer, enabling the interrupts, and the fuses were all the same. Just tried 4.114, and this too develops identical code.
One difference is the register 0xFD3, which is loaded with 0x74, instead of 0x72, in the initialisation. This is OSCCON, which controls the way the oscillator is configured. So looking, the later code is setup to run off the internal oscillator block, while the older code is set to run off the 'default primary oscillator', which is then set in CONFIG1H as the internal oscillator. These should both give the same result.
You can though change this by adding the line:
setup_oscillator(OSC_NORMAL|OSC_16MHZ);
I can't see though why that would change the behaviour of the secondary oscillator.
This though is the only register set differently when you reach the start of the printf statement, between the versions. |
overmindx
Posted: Mon Aug 11, 2014 9:43 am |
hi,
i tried placing
but it still wont work.
On a side note, i tried using v4.124 and it works. |
overmindx
Posted: Sun Jan 11, 2015 11:31 pm |
hi,
i just wanna revive this thread since i am still clueless why code involving timer1 will work on one version (4.124) and it wont work on (4.141). below is the code and .lst file for each version. please help so that this code will work for different versions and not just on 4.124.
code:
#device adc=12
#int_timer1
void timer1_isr(void)
output_toggle(PIN_E1);
output_low(PIN_E1);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_ENABLE_SOSC); //no T1_CLK_OUT
.lst file for 4.124
CCS PCH C Compiler, Version 4.124, 5967 12-Jan-15 12:21
Filename: E:\bryan\FIRMWARE 2014\timer1test.lst
ROM used: 324 bytes (0%)
Largest free fragment is 65536
RAM used: 28 (1%) at main() level
29 (1%) worst case
Stack: 2 worst case (1 in main + 1 for interrupts)
00000: GOTO 00F2
00008: MOVWF 04
0000A: MOVFF FD8,05
0000E: MOVFF FE0,06
00012: MOVLB 0
00014: MOVFF FE9,0C
00018: MOVFF FEA,07
0001C: MOVFF FE1,08
00020: MOVFF FE2,09
00024: MOVFF FD9,0A
00028: MOVFF FDA,0B
0002C: MOVFF FF3,12
00030: MOVFF FF4,13
00034: MOVFF FFA,14
00038: MOVFF FF5,15
0003C: MOVFF FF6,16
00040: MOVFF FF7,17
00044: MOVFF FF8,18
00048: MOVFF FFB,19
0004C: MOVFF 00,0E
00050: MOVFF 01,0F
00054: MOVFF 02,10
00058: MOVFF 03,11
0005C: BTFSS F9D.0
0005E: GOTO 0068
00062: BTFSC F9E.0
00064: GOTO 00BE
00068: MOVFF 0E,00
0006C: MOVFF 0F,01
00070: MOVFF 10,02
00074: MOVFF 11,03
00078: MOVFF 0C,FE9
0007C: MOVFF 07,FEA
00080: BSF 07.7
00082: MOVFF 08,FE1
00086: MOVFF 09,FE2
0008A: MOVFF 0A,FD9
0008E: MOVFF 0B,FDA
00092: MOVFF 12,FF3
00096: MOVFF 13,FF4
0009A: MOVFF 14,FFA
0009E: MOVFF 15,FF5
000A2: MOVFF 16,FF6
000A6: MOVFF 17,FF7
000AA: MOVFF 18,FF8
000AE: MOVFF 19,FFB
000B2: MOVF 04,W
000B4: MOVFF 06,FE0
000B8: MOVFF 05,FD8
000BC: RETFIE 0
.................... #include <18F67K22.h>
.................... //////// Standard Header file for the PIC18F67K22 device ////////////////
.................... #device PIC18F67K22
.................... #list
.................... #device adc=12
.................... #device PASS_STRINGS = IN_RAM
.................... #FUSES WDT_SW, WDT32768, INTRC_IO, NOPROTECT, NOIESO, BROWNOUT, PUT, NOCPD, STVREN, NODEBUG, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, NOXINST, MCLR, RTCOSC_T1
.................... #use delay(clock=16000000)
000C8: CLRF FEA
000CA: MOVLW 1C
000CC: MOVWF FE9
000CE: MOVF FEF,W
000D0: BZ 00EE
000D2: MOVLW 05
000D4: MOVWF 01
000D6: CLRF 00
000D8: DECFSZ 00,F
000DA: BRA 00D8
000DC: DECFSZ 01,F
000DE: BRA 00D6
000E0: MOVLW 2E
000E2: MOVWF 00
000E4: DECFSZ 00,F
000E6: BRA 00E4
000E8: BRA 00EA
000EA: DECFSZ FEF,F
000EC: BRA 00D2
000EE: GOTO 012A (RETURN)
.................... #int_timer1
.................... void timer1_isr(void)
.................... output_toggle(PIN_E1);
000BE: BCF F96.1
000C0: BTG F8D.1
000C2: BCF F9E.0
000C4: GOTO 0068
000F2: CLRF FF8
000F4: BCF FD0.7
000F6: BSF 07.7
000F8: CLRF FEA
000FA: CLRF FE9
000FC: MOVLW 72
000FE: MOVWF FD3
00100: CLRF F9B
00102: CLRF F64
00104: MOVLB 1
00106: CLRF x88
00108: MOVLW 00
0010A: MOVLB F
0010C: MOVWF x23
0010E: MOVWF x24
00110: MOVWF x25
00112: BCF FC1.3
00114: BCF FC1.4
00116: BCF FC1.5
00118: CLRF x2E
0011A: CLRF x2F
0011C: CLRF x54
.................... delay_ms(1000);
0011E: MOVLW 04
00120: MOVWF 1B
00122: MOVLW FA
00124: MOVWF 1C
00126: MOVLB 0
00128: BRA 00C8
0012A: DECFSZ 1B,F
0012C: BRA 0130
0012E: BRA 0134
00130: MOVLB F
00132: BRA 0122
.................... output_low(PIN_E1);
00134: BCF F96.1
00136: BCF F8D.1
.................... setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_ENABLE_SOSC); //no T1_CLK_OUT
00138: MOVLW 8F
0013A: MOVWF FCD
0013C: CLRF FAA
.................... enable_interrupts(INT_TIMER1);
0013E: BSF F9D.0
.................... enable_interrupts(GLOBAL);
00140: MOVLW C0
00142: IORWF FF2,F
.................... while(1);
00144: BRA 0144
00146: SLEEP
Configuration Fuses:
Word 1: 481D VREGSLEEP INTRC_HP SOSC_HIGH NOXINST INTRC_IO NOPLLEN FCMEN NOIESO
Word 2: 3E7E PUT BROWNOUT BORV18 ZPBORM WDT_SW WDT32768
Word 3: 8901 RTCOSC_T1 CCP2C1 MSSPMSK7 MCLR
Word 4: 0091 STVREN BBSIZ2K NODEBUG
Word 5: C0FF NOPROTECT NOCPB NOCPD
Word 6: E0FF NOWRT NOWRTC NOWRTB NOWRTD
Word 7: 40FF NOEBTR NOEBTRB
.lst file for 4.141
CCS PCH C Compiler, Version 4.141, 39552 12-Jan-15 12:27
Filename: D:\FILES\FIRMWARE 2014\timer1samp.lst
ROM used: 322 bytes (0%)
29 (1%) worst case
00000: GOTO 00F2
00008: MOVWF 04
0000A: MOVFF FD8,05
0000E: MOVFF FE0,06
00012: MOVLB 0
00014: MOVFF FE9,0C
00018: MOVFF FEA,07
0001C: MOVFF FE1,08
00020: MOVFF FE2,09
00024: MOVFF FD9,0A
00028: MOVFF FDA,0B
0002C: MOVFF FF3,12
00030: MOVFF FF4,13
00034: MOVFF FFA,14
00038: MOVFF FF5,15
0003C: MOVFF FF6,16
00040: MOVFF FF7,17
00044: MOVFF FF8,18
00048: MOVFF FFB,19
0004C: MOVFF 00,0E
00050: MOVFF 01,0F
00054: MOVFF 02,10
00058: MOVFF 03,11
0005C: BTFSS F9D.0
0005E: GOTO 0068
00062: BTFSC F9E.0
00064: GOTO 00BE
00068: MOVFF 0E,00
0006C: MOVFF 0F,01
00070: MOVFF 10,02
00074: MOVFF 11,03
00078: MOVFF 0C,FE9
0007C: MOVFF 07,FEA
00080: BSF 07.7
00082: MOVFF 08,FE1
00086: MOVFF 09,FE2
0008A: MOVFF 0A,FD9
0008E: MOVFF 0B,FDA
00092: MOVFF 12,FF3
00096: MOVFF 13,FF4
0009A: MOVFF 14,FFA
0009E: MOVFF 15,FF5
000A2: MOVFF 16,FF6
000A6: MOVFF 17,FF7
000AA: MOVFF 18,FF8
000AE: MOVFF 19,FFB
000B2: MOVF 04,W
000B4: MOVFF 06,FE0
000B8: MOVFF 05,FD8
000BC: RETFIE 0
000C8: CLRF FEA
000CA: MOVLW 1C
000CC: MOVWF FE9
000CE: MOVF FEF,W
000D0: BZ 00EE
000D2: MOVLW 05
000D4: MOVWF 01
000D6: CLRF 00
000D8: DECFSZ 00,F
000DA: BRA 00D8
000DC: DECFSZ 01,F
000DE: BRA 00D6
000E0: MOVLW 2E
000E2: MOVWF 00
000E4: DECFSZ 00,F
000E6: BRA 00E4
000E8: BRA 00EA
000EA: DECFSZ FEF,F
000EC: BRA 00D2
000EE: GOTO 0128 (RETURN)
000BE: BCF F96.1
000C0: BTG F8D.1
000C2: BCF F9E.0
000C4: GOTO 0068
000F2: CLRF FF8
000F4: BCF FD0.7
000F6: BSF 07.7
000F8: MOVLW 72
000FA: MOVWF FD3
000FC: CLRF F9B
000FE: CLRF F64
00100: MOVLW 00
00102: MOVLB F
00104: MOVWF x23
00106: MOVWF x24
00108: MOVWF x25
0010A: BCF FC1.3
0010C: BCF FC1.4
0010E: BCF FC1.5
00110: MOVLB 1
00112: CLRF x88
00114: MOVLB F
00116: CLRF x2E
00118: CLRF x2F
0011A: CLRF x54
0011C: MOVLW 04
0011E: MOVWF 1B
00120: MOVLW FA
00122: MOVWF 1C
00124: MOVLB 0
00126: BRA 00C8
00128: DECFSZ 1B,F
0012A: BRA 012E
0012C: BRA 0132
0012E: MOVLB F
00130: BRA 0120
00132: BCF F96.1
00134: BCF F8D.1
00136: MOVLW 8F
00138: MOVWF FCD
0013A: CLRF FAA
0013C: BSF F9D.0
0013E: MOVLW C0
00140: IORWF FF2,F
00142: BRA 0142
00144: SLEEP
Word 1: 4815 VREGSLEEP INTRC_HP SOSC_DIG NOXINST INTRC_IO NOPLLEN FCMEN NOIESO
Posted: Mon Jan 12, 2015 12:14 am |
Quote: | why code involving timer1 will work on one version (4.124) and it wont work on (4.141). |
Download the free version of Examdiff (vs. 1.9, exe). Compare both files:
http://www.prestosoft.com/edp_examdiff.asp
The first line of #fuses has a difference. It's the reason. |
overmindx
Posted: Mon Jan 12, 2015 12:46 am |
thank you PCM programmer.. |
