timer1 and 18f67k22
overmindx
timer1 and 18f67k22
PostPosted: Mon Aug 11, 2014 1:37 am     Reply with quote
hi,
how come this code doesnt work?
#include <18F67K22.h>
#device adc=12
#device PASS_STRINGS = IN_RAM
#FUSES WDT_SW, WDT32768, INTRC_IO, NOPROTECT, NOIESO, BROWNOUT, PUT, NOCPD, STVREN, NODEBUG, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, NOXINST, MCLR, RTCOSC_T1
#use delay(clock=16000000)
#use rs232(force_sw,baud=57600, xmit=PIN_G1, rcv=PIN_G2, stream=PC)
#Byte TMR1H = 0xFCF
#Byte T1CON = 0xFCD
int1 TESTFLAG=0;
#int_TIMER1
void TIMER1_isr()
   bit_clear(T1CON,1);
   bit_set(TMR1H,7);
   bit_set(T1CON,1);
   TESTFLAG=TRUE;
   delay_ms(2000);
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_ENABLE_SOSC);
   do{
      fprintf(PC,"TESTFLAG=%i\r",TESTFLAG);
   }while(1);
this code just outputs TESTFLAG=0.
my compiler version is 5.26. when i used a lower compiler version, this code works. please help.
thanks.
PostPosted: Mon Aug 11, 2014 3:15 am     Reply with quote
What version 'earlier compiler'?.
overmindx
PostPosted: Mon Aug 11, 2014 3:58 am     Reply with quote
if i used v.4.114 it outputs TESTFLAG=1
asmallri
PostPosted: Mon Aug 11, 2014 6:32 am     Reply with quote
In traditional C TESTFLAG should be declared volatile
Regards, Andrew
overmindx
PostPosted: Mon Aug 11, 2014 7:48 am     Reply with quote
hi,
i followed your suggestion by declaring TEST_FLAG as volatile but it still doesnt solve the problem. It seems for some reason isnt triggering the interrupt.
PostPosted: Mon Aug 11, 2014 8:44 am     Reply with quote
Odd.
I had already tried in 4.141, and this develops identical code setting up the timer, enabling the interrupts, and the fuses were all the same. Just tried 4.114, and this too develops identical code.
One difference is the register 0xFD3, which is loaded with 0x74, instead of 0x72, in the initialisation. This is OSCCON, which controls the way the oscillator is configured. So looking, the later code is setup to run off the internal oscillator block, while the older code is set to run off the 'default primary oscillator', which is then set in CONFIG1H as the internal oscillator. These should both give the same result.
You can though change this by adding the line:
setup_oscillator(OSC_NORMAL|OSC_16MHZ);
I can't see though why that would change the behaviour of the secondary oscillator.
This though is the only register set differently when you reach the start of the printf statement, between the versions.
overmindx
PostPosted: Mon Aug 11, 2014 9:43 am     Reply with quote
hi,
i tried placing
but it still wont work.
On a side note, i tried using v4.124 and it works.
overmindx
PostPosted: Sun Jan 11, 2015 11:31 pm     Reply with quote
hi,
i just wanna revive this thread since i am still clueless why code involving timer1 will work on one version (4.124) and it wont work on (4.141). below is the code and .lst file for each version. please help so that this code will work for different versions and not just on 4.124.
code:
#device adc=12
#int_timer1
void timer1_isr(void)
   output_toggle(PIN_E1);
   output_low(PIN_E1);
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_ENABLE_SOSC); //no T1_CLK_OUT
.lst file for 4.124
CCS PCH C Compiler, Version 4.124, 5967               12-Jan-15 12:21
               Filename: E:\bryan\FIRMWARE 2014\timer1test.lst
               ROM used: 324 bytes (0%)
                         Largest free fragment is 65536
               RAM used: 28 (1%) at main() level
                         29 (1%) worst case
               Stack:    2 worst case (1 in main + 1 for interrupts)
00000:  GOTO   00F2
00008:  MOVWF  04
0000A:  MOVFF  FD8,05
0000E:  MOVFF  FE0,06
00012:  MOVLB  0
00014:  MOVFF  FE9,0C
00018:  MOVFF  FEA,07
0001C:  MOVFF  FE1,08
00020:  MOVFF  FE2,09
00024:  MOVFF  FD9,0A
00028:  MOVFF  FDA,0B
0002C:  MOVFF  FF3,12
00030:  MOVFF  FF4,13
00034:  MOVFF  FFA,14
00038:  MOVFF  FF5,15
0003C:  MOVFF  FF6,16
00040:  MOVFF  FF7,17
00044:  MOVFF  FF8,18
00048:  MOVFF  FFB,19
0004C:  MOVFF  00,0E
00050:  MOVFF  01,0F
00054:  MOVFF  02,10
00058:  MOVFF  03,11
0005C:  BTFSS  F9D.0
0005E:  GOTO   0068
00062:  BTFSC  F9E.0
00064:  GOTO   00BE
00068:  MOVFF  0E,00
0006C:  MOVFF  0F,01
00070:  MOVFF  10,02
00074:  MOVFF  11,03
00078:  MOVFF  0C,FE9
0007C:  MOVFF  07,FEA
00080:  BSF    07.7
00082:  MOVFF  08,FE1
00086:  MOVFF  09,FE2
0008A:  MOVFF  0A,FD9
0008E:  MOVFF  0B,FDA
00092:  MOVFF  12,FF3
00096:  MOVFF  13,FF4
0009A:  MOVFF  14,FFA
0009E:  MOVFF  15,FF5
000A2:  MOVFF  16,FF6
000A6:  MOVFF  17,FF7
000AA:  MOVFF  18,FF8
000AE:  MOVFF  19,FFB
000B2:  MOVF   04,W
000B4:  MOVFF  06,FE0
000B8:  MOVFF  05,FD8
000BC:  RETFIE 0
.................... #include <18F67K22.h>
.................... //////// Standard Header file for the PIC18F67K22 device ////////////////
.................... #device PIC18F67K22
.................... #list
.................... #device adc=12
.................... #device PASS_STRINGS = IN_RAM
.................... #FUSES WDT_SW, WDT32768, INTRC_IO, NOPROTECT, NOIESO, BROWNOUT, PUT, NOCPD, STVREN, NODEBUG, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, NOXINST, MCLR, RTCOSC_T1
.................... #use delay(clock=16000000)
000C8:  CLRF   FEA
000CA:  MOVLW  1C
000CC:  MOVWF  FE9
000CE:  MOVF   FEF,W
000D0:  BZ    00EE
000D2:  MOVLW  05
000D4:  MOVWF  01
000D6:  CLRF   00
000D8:  DECFSZ 00,F
000DA:  BRA    00D8
000DC:  DECFSZ 01,F
000DE:  BRA    00D6
000E0:  MOVLW  2E
000E2:  MOVWF  00
000E4:  DECFSZ 00,F
000E6:  BRA    00E4
000E8:  BRA    00EA
000EA:  DECFSZ FEF,F
000EC:  BRA    00D2
000EE:  GOTO   012A (RETURN)
.................... #int_timer1
.................... void timer1_isr(void)
....................    output_toggle(PIN_E1);
000BE:  BCF    F96.1
000C0:  BTG    F8D.1
000C2:  BCF    F9E.0
000C4:  GOTO   0068
000F2:  CLRF   FF8
000F4:  BCF    FD0.7
000F6:  BSF    07.7
000F8:  CLRF   FEA
000FA:  CLRF   FE9
000FC:  MOVLW  72
000FE:  MOVWF  FD3
00100:  CLRF   F9B
00102:  CLRF   F64
00104:  MOVLB  1
00106:  CLRF   x88
00108:  MOVLW  00
0010A:  MOVLB  F
0010C:  MOVWF  x23
0010E:  MOVWF  x24
00110:  MOVWF  x25
00112:  BCF    FC1.3
00114:  BCF    FC1.4
00116:  BCF    FC1.5
00118:  CLRF   x2E
0011A:  CLRF   x2F
0011C:  CLRF   x54
....................    delay_ms(1000);
0011E:  MOVLW  04
00120:  MOVWF  1B
00122:  MOVLW  FA
00124:  MOVWF  1C
00126:  MOVLB  0
00128:  BRA    00C8
0012A:  DECFSZ 1B,F
0012C:  BRA    0130
0012E:  BRA    0134
00130:  MOVLB  F
00132:  BRA    0122
....................    output_low(PIN_E1);
00134:  BCF    F96.1
00136:  BCF    F8D.1
....................    setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_ENABLE_SOSC); //no T1_CLK_OUT
00138:  MOVLW  8F
0013A:  MOVWF  FCD
0013C:  CLRF   FAA
....................    enable_interrupts(INT_TIMER1);
0013E:  BSF    F9D.0
....................    enable_interrupts(GLOBAL);
00140:  MOVLW  C0
00142:  IORWF  FF2,F
....................    while(1);
00144:  BRA    0144
00146:  SLEEP
Configuration Fuses:
   Word  1: 481D   VREGSLEEP INTRC_HP SOSC_HIGH NOXINST INTRC_IO NOPLLEN FCMEN NOIESO
   Word  2: 3E7E   PUT BROWNOUT BORV18 ZPBORM WDT_SW WDT32768
   Word  3: 8901   RTCOSC_T1 CCP2C1 MSSPMSK7 MCLR
   Word  4: 0091   STVREN BBSIZ2K NODEBUG
   Word  5: C0FF   NOPROTECT NOCPB NOCPD
   Word  6: E0FF   NOWRT NOWRTC NOWRTB NOWRTD
   Word  7: 40FF   NOEBTR NOEBTRB
.lst file for 4.141
CCS PCH C Compiler, Version 4.141, 39552               12-Jan-15 12:27
               Filename:   D:\FILES\FIRMWARE 2014\timer1samp.lst
               ROM used:   322 bytes (0%)
                           29 (1%) worst case
00000:  GOTO   00F2
00008:  MOVWF  04
0000A:  MOVFF  FD8,05
0000E:  MOVFF  FE0,06
00012:  MOVLB  0
00014:  MOVFF  FE9,0C
00018:  MOVFF  FEA,07
0001C:  MOVFF  FE1,08
00020:  MOVFF  FE2,09
00024:  MOVFF  FD9,0A
00028:  MOVFF  FDA,0B
0002C:  MOVFF  FF3,12
00030:  MOVFF  FF4,13
00034:  MOVFF  FFA,14
00038:  MOVFF  FF5,15
0003C:  MOVFF  FF6,16
00040:  MOVFF  FF7,17
00044:  MOVFF  FF8,18
00048:  MOVFF  FFB,19
0004C:  MOVFF  00,0E
00050:  MOVFF  01,0F
00054:  MOVFF  02,10
00058:  MOVFF  03,11
0005C:  BTFSS  F9D.0
0005E:  GOTO   0068
00062:  BTFSC  F9E.0
00064:  GOTO   00BE
00068:  MOVFF  0E,00
0006C:  MOVFF  0F,01
00070:  MOVFF  10,02
00074:  MOVFF  11,03
00078:  MOVFF  0C,FE9
0007C:  MOVFF  07,FEA
00080:  BSF    07.7
00082:  MOVFF  08,FE1
00086:  MOVFF  09,FE2
0008A:  MOVFF  0A,FD9
0008E:  MOVFF  0B,FDA
00092:  MOVFF  12,FF3
00096:  MOVFF  13,FF4
0009A:  MOVFF  14,FFA
0009E:  MOVFF  15,FF5
000A2:  MOVFF  16,FF6
000A6:  MOVFF  17,FF7
000AA:  MOVFF  18,FF8
000AE:  MOVFF  19,FFB
000B2:  MOVF   04,W
000B4:  MOVFF  06,FE0
000B8:  MOVFF  05,FD8
000BC:  RETFIE 0
000C8:  CLRF   FEA
000CA:  MOVLW  1C
000CC:  MOVWF  FE9
000CE:  MOVF   FEF,W
000D0:  BZ    00EE
000D2:  MOVLW  05
000D4:  MOVWF  01
000D6:  CLRF   00
000D8:  DECFSZ 00,F
000DA:  BRA    00D8
000DC:  DECFSZ 01,F
000DE:  BRA    00D6
000E0:  MOVLW  2E
000E2:  MOVWF  00
000E4:  DECFSZ 00,F
000E6:  BRA    00E4
000E8:  BRA    00EA
000EA:  DECFSZ FEF,F
000EC:  BRA    00D2
000EE:  GOTO   0128 (RETURN)
000BE:  BCF    F96.1
000C0:  BTG    F8D.1
000C2:  BCF    F9E.0
000C4:  GOTO   0068
000F2:  CLRF   FF8
000F4:  BCF    FD0.7
000F6:  BSF    07.7
000F8:  MOVLW  72
000FA:  MOVWF  FD3
000FC:  CLRF   F9B
000FE:  CLRF   F64
00100:  MOVLW  00
00102:  MOVLB  F
00104:  MOVWF  x23
00106:  MOVWF  x24
00108:  MOVWF  x25
0010A:  BCF    FC1.3
0010C:  BCF    FC1.4
0010E:  BCF    FC1.5
00110:  MOVLB  1
00112:  CLRF   x88
00114:  MOVLB  F
00116:  CLRF   x2E
00118:  CLRF   x2F
0011A:  CLRF   x54
0011C:  MOVLW  04
0011E:  MOVWF  1B
00120:  MOVLW  FA
00122:  MOVWF  1C
00124:  MOVLB  0
00126:  BRA    00C8
00128:  DECFSZ 1B,F
0012A:  BRA    012E
0012C:  BRA    0132
0012E:  MOVLB  F
00130:  BRA    0120
00132:  BCF    F96.1
00134:  BCF    F8D.1
00136:  MOVLW  8F
00138:  MOVWF  FCD
0013A:  CLRF   FAA
0013C:  BSF    F9D.0
0013E:  MOVLW  C0
00140:  IORWF  FF2,F
00142:  BRA    0142
00144:  SLEEP
   Word  1: 4815   VREGSLEEP INTRC_HP SOSC_DIG NOXINST INTRC_IO NOPLLEN FCMEN NOIESO
PostPosted: Mon Jan 12, 2015 12:14 am     Reply with quote
Download the free version of Examdiff (vs. 1.9, exe). Compare both files:
http://www.prestosoft.com/edp_examdiff.asp
The first line of #fuses has a difference. It's the reason.
overmindx
PostPosted: Mon Jan 12, 2015 12:46 am     Reply with quote
thank you PCM programmer..
