hello,
I am trying to use the DS1077 programmable oscillator with the dspic33ep256mu806. My problem is that when I write the device address on the I2C line connected to the DS1077 I don't get an ACK signal back. My microcontroller and support circuitry are ok since I have used the same circuit previously to run the adc and other applications. I am copying the parts of my code that setup the DS1077 and I2C below. Can any one point out if there is a mistake in it? Thanks for your help.
I assume you have the pullups on the clock and data lines...and the ds1077 address lines are all grounded. _________________ Google and Forum Search are some of your best tools!!!!
