Selection for MODBUS ADDRESS and MODBUS_SERIAL_BAUD
Posted: Thu Sep 18, 2014 2:37 am
I am using ex_modbus_slave.c file of CCS compiler version 4.119. The code working fine. But I need to provide the selection of Baud rates for communication. Instead of fixed baud rate I need flexible baud rates which can be selected by end user.
It gives duplicate define warning. Please advise how to assign multiple baud rate options in this code.
Thanks,
Paddy
Posted: Thu Sep 18, 2014 2:57 am
You don't directly.
You build the code to handle one rate (19200bps, or 9600bps say).
Then use the 'set_uart_speed' command to select the rate you actually want to run.
So you have a command from the keyboard, or an external DIP switch (for example), that chooses from perhaps four rates, and then just call set_uart_speed(xxxx), to chose the rate.
