Selection for MODBUS ADDRESS and MODBUS_SERIAL_BAUD
paddy
PostPosted: Thu Sep 18, 2014 2:37 am     Reply with quote
I am using ex_modbus_slave.c file of CCS compiler version 4.119. The code working fine. But I need to provide the selection of Baud rates for communication. Instead of fixed baud rate I need flexible baud rates which can be selected by end user.
/////////////////     Setting Modbus parameters      ////////////////////
#define MODBUS_TYPE                       MODBUS_TYPE_SLAVE
#define MODBUS_SERIAL_TYPE                MODBUS_RTU
#define MODBUS_SERIAL_INT_SOURCE          MODBUS_INT_RDA
#define MODBUS_SERIAL_RX_BUFFER_SIZE      64
//#define MODBUS_SERIAL_BAUD              9600
#define MODBUS_SERIAL_RX_PIN              PIN_C7
#define MODBUS_SERIAL_TX_PIN              PIN_C6
#define MODBUS_SERIAL_ENABLE_PIN          Pin_C5
#define MODBUS_SERIAL_RX_ENABLE           Pin_C5
#include <modbus.c>
#define MODBUS_ADDRESS       Channel_No
#define MODBUS_SERIAL_BAUD   Baud_Rate
It gives duplicate define warning. Please advise how to assign multiple baud rate options in this code.
Thanks,
Paddy
PostPosted: Thu Sep 18, 2014 2:57 am     Reply with quote
You don't directly.
You build the code to handle one rate (19200bps, or 9600bps say).
Then use the 'set_uart_speed' command to select the rate you actually want to run.
So you have a command from the keyboard, or an external DIP switch (for example), that chooses from perhaps four rates, and then just call set_uart_speed(xxxx), to chose the rate.
