diogoc
Hex file don't works after rebuilding |
Posted: Mon Mar 24, 2014 5:18 am |
I'm using CCS V5.021 with a multiple compilation project. The pic is a PIC18F26K22.
When I build for the first time the project it works fine, but if I rebuild the project the pic has an erratic functioning, even if I make no changes in the code. I compared both of the .lst files and the second one is a little larger.
So when I change something in my code I have to close the CCS ide and delete ALL created files during the compilation. In the versions 4.xxx it did not happen.
It is a bug of the V5 compiler? |
Posted: Mon Mar 24, 2014 10:13 am |
Try to do it without Multiple Compilation Units. Does it still fail in the
same way ? |
diogoc
Posted: Tue Mar 25, 2014 12:33 pm |
It is strange, it seems that after rebuilding the circuit is more sensible to noise because the firmware hangs when there are connected long wires.
But I still donĀ“t understand why the hex file is different when I rebuild the firmware.
I tried with single compilation unit and the files are still different. |
Posted: Tue Mar 25, 2014 1:48 pm |
Regarding your noise problem, see this thread about floating pins:
http://www.ccsinfo.com/forum/viewtopic.php?t=45371
This is a 2-page thread.
Quote: | I tried with single compilation unit and the files are still different. |
So this means you disabled "Multiple Compilation Units" and you added
.c and .h modules to your main C file with #include statements, then you
compiled the main C file.
And then, even after doing that, every time you compile the project, you
still get a different Hex file size every time ? And you're not using MCU's
at all. |
diogoc
Posted: Wed Mar 26, 2014 3:33 am |
PCM programmer wrote: | So this means you disabled "Multiple Compilation Units" and you added
at all. |
Yes I disabled "Multiple Compilation Units", copy all functions to the main.c file and remove the other files.
When I compile the second time, the hex file is a few bytes larger. The rebuild button should rebuild the whole project again but I don't get the initial size. |
diogoc
Posted: Wed Mar 26, 2014 3:55 am |
I have compared the .lst files and the differences are in the beginning of the main function, in the "DATA xx, xx" instruction:
.................... void main(void) {
03C60: CLRF FF8
03C62: BCF FF1.2
03C64: BSF F9F.1
03C66: BCF FF0.6
03C68: BCF F9F.5
03C6A: BSF FD0.7
03C6C: BSF 07.7
03C6E: MOVLW 70
03C70: MOVWF FD3
03C72: BSF F9B.6
03C74: BCF F9B.7
03C76: CLRF 28
03C78: BSF FB8.3
03C7A: MOVLW 40
03C7C: MOVWF FAF
03C7E: MOVLW 03
03C80: MOVWF FB0
03C82: MOVLW A6
03C84: MOVWF FAC
03C86: MOVLW 90
03C88: MOVWF FAB
03C8A: MOVLW 01
03C8C: MOVWF 59
03C8E: CLRF 5A
03C90: CLRF 5C
03C92: CLRF 5B
03C94: CLRF 5D
03C96: CLRF 5E
03C98: CLRF x60
03C9A: CLRF 5F
03C9C: MOVLW 03
03C9E: MOVWF x62
03CA0: SETF x61
03CA2: CLRF x64
03CA4: CLRF x63
03CA6: CLRF x65
03CA8: CLRF x66
03CAA: CLRF x67
03CAC: CLRF x68
03CAE: CLRF x6A
03CB0: CLRF x69
03CB2: CLRF x6B
03CB4: MOVLW 01
03CB6: MOVWF x6C
03CB8: CLRF x70
03CBA: CLRF x6F
03CBC: CLRF x6E
03CBE: CLRF x6D
03CC0: CLRF x74
03CC2: CLRF x73
03CC4: CLRF x72
03CC6: CLRF x71
03CC8: CLRF x76
03CCA: CLRF x75
03CCC: CLRF x78
03CCE: CLRF x77
03CD0: MOVLW 14
03CD2: MOVWF x79
03CD4: CLRF x9A
03CD6: CLRF x9B
03CD8: MOVLW 01
03CDA: MOVWF x9C
03CDC: CLRF xA5
03CDE: CLRF xA7
03CE0: CLRF xA6
03CE2: CLRF xA8
03CE4: BRA 3E48
03CE6: DATA 08,40
03CE8: DATA 31,00
03CEA: DATA 08,40
03CEC: DATA 35,00
03CEE: DATA 08,40
03CF0: DATA 39,00
03CF2: DATA 08,40
03CF4: DATA 3D,00
