Hex file don't works after rebuilding
diogoc
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Mon Mar 24, 2014 5:18 am     Reply with quote
I'm using CCS V5.021 with a multiple compilation project. The pic is a PIC18F26K22.
When I build for the first time the project it works fine, but if I rebuild the project the pic has an erratic functioning, even if I make no changes in the code. I compared both of the .lst files and the second one is a little larger.
So when I change something in my code I have to close the CCS ide and delete ALL created files during the compilation. In the versions 4.xxx it did not happen.
It is a bug of the V5 compiler?
PostPosted: Mon Mar 24, 2014 10:13 am     Reply with quote
Try to do it without Multiple Compilation Units. Does it still fail in the
same way ?
diogoc
PostPosted: Tue Mar 25, 2014 12:33 pm     Reply with quote
It is strange, it seems that after rebuilding the circuit is more sensible to noise because the firmware hangs when there are connected long wires.
But I still donĀ“t understand why the hex file is different when I rebuild the firmware.
I tried with single compilation unit and the files are still different.
PostPosted: Tue Mar 25, 2014 1:48 pm     Reply with quote
Regarding your noise problem, see this thread about floating pins:
http://www.ccsinfo.com/forum/viewtopic.php?t=45371
This is a 2-page thread.
So this means you disabled "Multiple Compilation Units" and you added
.c and .h modules to your main C file with #include statements, then you
compiled the main C file.
And then, even after doing that, every time you compile the project, you
still get a different Hex file size every time ? And you're not using MCU's
at all.
diogoc
PostPosted: Wed Mar 26, 2014 3:33 am     Reply with quote
at all.
Yes I disabled "Multiple Compilation Units", copy all functions to the main.c file and remove the other files.
When I compile the second time, the hex file is a few bytes larger. The rebuild button should rebuild the whole project again but I don't get the initial size.
diogoc
PostPosted: Wed Mar 26, 2014 3:55 am     Reply with quote
I have compared the .lst files and the differences are in the beginning of the main function, in the "DATA xx, xx" instruction:
.................... void main(void) {
03C60:  CLRF   FF8
03C62:  BCF    FF1.2
03C64:  BSF    F9F.1
03C66:  BCF    FF0.6
03C68:  BCF    F9F.5
03C6A:  BSF    FD0.7
03C6C:  BSF    07.7
03C6E:  MOVLW  70
03C70:  MOVWF  FD3
03C72:  BSF    F9B.6
03C74:  BCF    F9B.7
03C76:  CLRF   28
03C78:  BSF    FB8.3
03C7A:  MOVLW  40
03C7C:  MOVWF  FAF
03C7E:  MOVLW  03
03C80:  MOVWF  FB0
03C82:  MOVLW  A6
03C84:  MOVWF  FAC
03C86:  MOVLW  90
03C88:  MOVWF  FAB
03C8A:  MOVLW  01
03C8C:  MOVWF  59
03C8E:  CLRF   5A
03C90:  CLRF   5C
03C92:  CLRF   5B
03C94:  CLRF   5D
03C96:  CLRF   5E
03C98:  CLRF   x60
03C9A:  CLRF   5F
03C9C:  MOVLW  03
03C9E:  MOVWF  x62
03CA0:  SETF   x61
03CA2:  CLRF   x64
03CA4:  CLRF   x63
03CA6:  CLRF   x65
03CA8:  CLRF   x66
03CAA:  CLRF   x67
03CAC:  CLRF   x68
03CAE:  CLRF   x6A
03CB0:  CLRF   x69
03CB2:  CLRF   x6B
03CB4:  MOVLW  01
03CB6:  MOVWF  x6C
03CB8:  CLRF   x70
03CBA:  CLRF   x6F
03CBC:  CLRF   x6E
03CBE:  CLRF   x6D
03CC0:  CLRF   x74
03CC2:  CLRF   x73
03CC4:  CLRF   x72
03CC6:  CLRF   x71
03CC8:  CLRF   x76
03CCA:  CLRF   x75
03CCC:  CLRF   x78
03CCE:  CLRF   x77
03CD0:  MOVLW  14
03CD2:  MOVWF  x79
03CD4:  CLRF   x9A
03CD6:  CLRF   x9B
03CD8:  MOVLW  01
03CDA:  MOVWF  x9C
03CDC:  CLRF   xA5
03CDE:  CLRF   xA7
03CE0:  CLRF   xA6
03CE2:  CLRF   xA8
03CE4:  BRA    3E48
03CE6:  DATA 08,40
03CE8:  DATA 31,00
03CEA:  DATA 08,40
03CEC:  DATA 35,00
03CEE:  DATA 08,40
03CF0:  DATA 39,00
03CF2:  DATA 08,40
03CF4:  DATA 3D,00
