MCP23008 reading port
aaronik19
PostPosted: Sat May 11, 2013 6:07 pm     Reply with quote
hello friends,
I have the following code:
   MCP23008_write(MCP23008_3_write, _IODIR, 0xFF); // All Pins are Inputs
   MCP23008_write(MCP23008_3_write, _IPOL, 0x00); // All Outputs are similar to inputs
   MCP23008_write(MCP23008_3_write, _GPINTEN, 0xFF); //All Interrupt on Change
   MCP23008_write(MCP23008_3_write, _DEFVAL, 0x00); //To Compare GPINTEN & INTCON against DEFVAL
   MCP23008_write(MCP23008_3_write, _INTCON 0xFF); //Compare with 0 value
   MCP23008_write(MCP23008_3_write, _IOCON, 0x02); //int active high
   MCP23008_write(MCP23008_3_write, _GPPU, 0x00); // Disable Pull-Up Resistors
   MCP23008_write(MCP23008_3_write, _INTF, 0x00);
   MCP23008_write(MCP23008_3_write, _GPIO, 0x00);
   MCP23008_write(MCP23008_3_write, _OLAT, 0x00);
the problem is that the setup is good but the interrupt is not being fired. I am sending this code to setup the MCP23008 as input (read) on Interrupt change. I read all the datasheet and related application note but still in the same problem. Can someone please guide me if I've setup the MCP23008 correctly?
PostPosted: Sun May 12, 2013 11:36 am     Reply with quote
without source code for
MCP23008_write()
and how you use it in MAIN()
how can anybody tell what
is going on ??
aaronik19
PostPosted: Sat Mar 01, 2014 10:26 pm     Reply with quote
dear all,
I continue to work on this chip and still have problems to clear interrupt when read the INTCON register. This is the driver code:
 FUNCTIONS DEFINITIONS
#define MCP23008_1_write 0x4E
#define MCP23008_1_read 0x4F
#define MCP23008_2_write 0x48
#define MCP23008_2_read 0x49
#define MCP23008_3_write 0x4C
#define MCP23008_3_read 0x4D
// MCP23008 REGISTERS
#define _IODIR       0x00 // determines if the pin is input or output
#define _IPOL        0x01 // the polarity of the input. Can have invert input
#define _GPINTEN     0x02 // interrupt on change input
#define _DEFVAL      0x03 // default comparision
#define _INTCON      0x04 // compare with the DEFVAL during interrupt
#define _IOCON       0x05 // I/O Expander configuration
#define _GPPU        0x06 // pull-up resistors
#define _INTF        0x07 // interrupt flag
#define _INTCAP      0x08 // capture the state of the port during interrupt
#define _GPIO        0x09 // actual input/outputs on the port
#define _OLAT        0x0A // logic level register of the output port
long int MCP23008_read(unsigned int WriteAddress, unsigned int cmdByte, unsigned int ReadAddress)
   unsigned int data;
   i2c_start();             // start condition
   delay_us(20);
   i2c_write(WriteAddress);    // Send slave address and clear (R/W_)
   delay_us(20);
   i2c_write(cmdByte);       // Command byte and register to be written.
   delay_us(50);
   i2c_start();
   delay_us(20);             // restart condition
   i2c_write(ReadAddress);      // Send slave address and clear (R_/W)
   delay_us(20);
   data = i2c_read();       // Data from LSB or MSB of register
   delay_us(20);
   i2c_stop();             // stop condition
   return(data);
void MCP23008_write(unsigned char location, unsigned char addr, unsigned char data)
i2c_start();
delay_us(20);
i2c_write(location);
delay_us(20);
i2c_write(addr);
delay_us(20);
i2c_write(data);
delay_us(20);
i2c_stop();
delay_us(20);
void MCP23008_init()
   output_float(PIN_C4);
   output_float(PIN_C3); //signals to prepare MCP for operation
   delay_ms(250);   //delay for MCP23008 start-up
   MCP23008_write(MCP23008_1_write, _IODIR, 0x00); // All Pins are Outputs
   MCP23008_write(MCP23008_1_write, _IPOL, 0x00); // All Outputs are similar to inputs
   MCP23008_write(MCP23008_1_write, _IOCON, 0x00);
   MCP23008_write(MCP23008_2_write, _IODIR, 0x00); // All Pins are Outputs
   MCP23008_write(MCP23008_2_write, _IPOL, 0x00); // All Outputs are similar to inputs
   MCP23008_write(MCP23008_2_write, _IOCON, 0x00);
   MCP23008_write(MCP23008_3_write, _INTCON 0xFF); //Compare with Defcal Register
   MCP23008_write(MCP23008_3_write, _IOCON, 0x0A);
   MCP23008_write(MCP23008_3_write, _IOCON, 0x00);
the main code is:
#include <program.h>
#include <mcp23008.c>
//VARIABLES FOR THE PROGRAM
int counter1 = 0;
int GP_count = 0;
int8 read_port = 0;
#INT_EXT
void  EXT_isr(void)
   output_high(PIN_D1);
   output_high(PIN_D2);
   read_port = MCP23008_Read(0x4C,0x08, 0x4D);
   output_low(PIN_D1);
   mcp23008_write(0x48, 0x09, read_port);
   output_low(PIN_D2);
   mcp23008_init();
   enable_interrupts(INT_EXT);
   ext_int_edge( H_TO_L );
I also draw the circuit on proteus but this is real simulation and not software simulation. Used proteus only to show the circuit
http://postimg.org/image/47llzictt/
PostPosted: Sat Mar 01, 2014 10:38 pm     Reply with quote
This is the same old problem. It's missing the NAK on the last i2c_read
in your MCP23008_read() function.
In your thread here, from 2011, you had the NAK in there. Why did
you take it out in your latest code ? It's essential:
http://www.ccsinfo.com/forum/viewtopic.php?t=46502
In this thread here, which looks like the place you got the driver from,
he makes the missing NAK mistake and I correct it:
http://www.ccsinfo.com/forum/viewtopic.php?t=22639
aaronik19
PostPosted: Sun Mar 02, 2014 12:09 am     Reply with quote
thanks I solve that problem. I forgot the "0"...thanks
But the problem is that When I press the button, the interrupt is working and it is being written on the second MCP chip. The problem is that when I press another button nothing is happening. ON the datasheet it is mentioned that when the register INTCON (0x08) is being read, the interrupt will be reset. Do I missing something please?
aaronik19
PostPosted: Sun Mar 02, 2014 9:29 am     Reply with quote
Afterr more time trying, i am still have no success....any help please?
Mike Walne
PostPosted: Sun Mar 02, 2014 2:16 pm     Reply with quote
Reduce your code to a few lines so showing us what your real problem is.
Mike
