little change in input.c in example file gives error
maxD
PostPosted: Sat Dec 28, 2013 12:47 am     Reply with quote
hi i've compiled the input.c as here
#include<18f2550.h>
#include<stdlib.h>
#fuses NOWDT,HS,NOPROTECT,NOLVP
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,INVERT,parity=N,bits=8)
//#ifndef __INPUT_C__
//#define __INPUT_C__
#include <string.h>
#if defined(STREAM_SERIAL_INPUT)
   #define InputKbhit()    kbhit(STREAM_SERIAL_INPUT)
   #define InputPutc(c)    fputc(c, STREAM_SERIAL_INPUT)
   #define InputGetc()     fgetc(STREAM_SERIAL_INPUT)
#else
   #define InputKbhit()    kbhit()
   #define InputPutc(c)    putc(c)
   #define InputGetc()     getc()
#endif
unsigned int8 gethex1() {
   char digit;
   digit = InputGetc();
   InputPutc(digit);
   if(digit<='9')
     return(digit-'0');
     return((toupper(digit)-'A')+10);
unsigned int8 gethex() {
   unsigned int8 lo,hi;
   hi = gethex1();
   lo = gethex1();
   if(lo==0xdd)
     return(hi);
     return( hi*16+lo );
void get_string(char* s, unsigned int8 max) {
   unsigned int8 len;
   char c;
   max-=2;
   len=0;
   do {
     c=InputGetc();
     if(c==8) {  // Backspace
        if(len>0) {
          len--;
          InputPutc(c);
          InputPutc(' ');
          InputPutc(c);
     } else if ((c>=' ')&&(c<='~'))
       if(len<=max) {
         s[len++]=c;
         InputPutc(c);
   } while(c!=13);
   s[len]=0;
#ifdef _STRING
void get_stringEdit(char* s, unsigned int8 max) {
   unsigned int8 len;
   char c;
   len = strlen(s);
   if (len)
      fprintf(STREAM_SERIAL_INPUT, "%s", s);
     #else
      printf("%s", s);
     #endif
   max-=2;
   do {
     c=InputGetc();
        if(len>0) {
          len--;
          InputPutc(c);
          InputPutc(' ');
          InputPutc(c);
       if(len<=max) {
         s[len++]=c;
         InputPutc(c);
   } while(c!=13);
   s[len]=0;
#endif
// stdlib.h is required for the ato_ conversions
// in the following functions
#ifdef _STDLIB
signed int8 get_Int8(void)
  char s[5];
  signed int8 i;
  get_string(s, sizeof(s));
  i=atoi(s);
  return(i);
#ifdef _STRING
signed int8 get_Int8Edit(signed int8 old)
  char s[5];
  signed int8 i;
  sprintf(s, "%d", old);
  get_stringEdit(s, sizeof(s));
  i=atoi(s);
  return(i);
#endif
signed int16 get_Int16(void)
  char s[7];
  signed int16 l;
  l=atol(s);
  return(l);
#ifdef _STRING
signed int16 get_Int16Edit(signed int16 old)
  char s[7];
  signed int16 l;
  sprintf(s, "%ld", old);
  l=atol(s);
  return(l);
#endif
signed int32 get_Int32(void)
  char s[12];
  signed int32 l;
  l=atoi32(s);
  return(l);
#ifdef _STRING
signed int32 get_Int32Edit(signed int32 old)
  char s[12];
  signed int32 l;
  l=atoi32(s);
  return(l);
#endif
float get_float() {
  char s[20];
  float f;
  get_string(s, 20);
  f = atof(s);
  return(f);
#ifdef _STRING
float get_floatEdit(float old) {
  char s[20];
  float f;
  sprintf(s, "%f", old);
  get_string(s, 20);
  f = atof(s);
  return(f);
#endif
#if defined(__PCD__)
   #define get_int()       get_Int16()
   #define get_intEdit()   get_Int16Edit()
   #define get_long()      get_Int32()
   #define get_longEdit()  get_Int32Edit()
#else
   #define get_int()       get_Int8()
   #define get_intEdit()   get_Int8Edit()
   #define get_long()      get_Int16()
   #define get_longEdit()  get_Int16Edit()
#endif
#endif   //_STDLIB
#endif   //__INPUT_C__//error high lights here
The error is line 274[2,7] expecting function name
Can you tell me how to fix this ?
PostPosted: Sat Dec 28, 2013 12:57 am     Reply with quote
You have no main() function. That's the reason.
Also, don't try to compile CCS driver files as a "program". They are
intended to be added to your main program with an #include statement.
Also, in the general case, do not edit CCS driver files.
