maxD
little change in input.c in example file gives error |
Posted: Sat Dec 28, 2013 12:47 am |
hi i've compiled the input.c as here
#include<18f2550.h>
#include<stdlib.h>
#fuses NOWDT,HS,NOPROTECT,NOLVP
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,INVERT,parity=N,bits=8)
//#ifndef __INPUT_C__
//#define __INPUT_C__
#include <string.h>
#if defined(STREAM_SERIAL_INPUT)
#define InputKbhit() kbhit(STREAM_SERIAL_INPUT)
#define InputPutc(c) fputc(c, STREAM_SERIAL_INPUT)
#define InputGetc() fgetc(STREAM_SERIAL_INPUT)
#else
#define InputKbhit() kbhit()
#define InputPutc(c) putc(c)
#define InputGetc() getc()
unsigned int8 gethex1() {
char digit;
digit = InputGetc();
InputPutc(digit);
if(digit<='9')
return(digit-'0');
return((toupper(digit)-'A')+10);
unsigned int8 gethex() {
unsigned int8 lo,hi;
hi = gethex1();
lo = gethex1();
if(lo==0xdd)
return(hi);
return( hi*16+lo );
void get_string(char* s, unsigned int8 max) {
unsigned int8 len;
char c;
max-=2;
len=0;
do {
c=InputGetc();
if(c==8) { // Backspace
if(len>0) {
len--;
InputPutc(c);
InputPutc(' ');
InputPutc(c);
} else if ((c>=' ')&&(c<='~'))
if(len<=max) {
s[len++]=c;
InputPutc(c);
} while(c!=13);
s[len]=0;
#ifdef _STRING
void get_stringEdit(char* s, unsigned int8 max) {
unsigned int8 len;
char c;
len = strlen(s);
if (len)
fprintf(STREAM_SERIAL_INPUT, "%s", s);
#else
printf("%s", s);
max-=2;
do {
c=InputGetc();
if(len>0) {
len--;
InputPutc(c);
InputPutc(' ');
InputPutc(c);
if(len<=max) {
s[len++]=c;
InputPutc(c);
} while(c!=13);
s[len]=0;
// stdlib.h is required for the ato_ conversions
// in the following functions
#ifdef _STDLIB
signed int8 get_Int8(void)
char s[5];
signed int8 i;
get_string(s, sizeof(s));
i=atoi(s);
return(i);
#ifdef _STRING
signed int8 get_Int8Edit(signed int8 old)
char s[5];
signed int8 i;
sprintf(s, "%d", old);
get_stringEdit(s, sizeof(s));
i=atoi(s);
return(i);
signed int16 get_Int16(void)
char s[7];
signed int16 l;
l=atol(s);
return(l);
#ifdef _STRING
signed int16 get_Int16Edit(signed int16 old)
char s[7];
signed int16 l;
sprintf(s, "%ld", old);
l=atol(s);
return(l);
signed int32 get_Int32(void)
char s[12];
signed int32 l;
l=atoi32(s);
return(l);
#ifdef _STRING
signed int32 get_Int32Edit(signed int32 old)
char s[12];
signed int32 l;
l=atoi32(s);
return(l);
float get_float() {
char s[20];
float f;
get_string(s, 20);
f = atof(s);
return(f);
#ifdef _STRING
float get_floatEdit(float old) {
char s[20];
float f;
sprintf(s, "%f", old);
get_string(s, 20);
f = atof(s);
return(f);
#if defined(__PCD__)
#define get_int() get_Int16()
#define get_intEdit() get_Int16Edit()
#define get_long() get_Int32()
#define get_longEdit() get_Int32Edit()
#else
#define get_int() get_Int8()
#define get_intEdit() get_Int8Edit()
#define get_long() get_Int16()
#define get_longEdit() get_Int16Edit()
#endif //_STDLIB
#endif //__INPUT_C__//error high lights here
The error is line 274[2,7] expecting function name
Can you tell me how to fix this ? |
Posted: Sat Dec 28, 2013 12:57 am |
You have no main() function. That's the reason.
Also, don't try to compile CCS driver files as a "program". They are
intended to be added to your main program with an #include statement.
Also, in the general case, do not edit CCS driver files. |
