jameszum
MPLAB ICD 2 in debug mode |
Posted: Tue Jan 31, 2012 4:28 pm |
I am trying to use a MPLAB ICD 2 to debug code for a "24F16KA102" on a "16 bit XLP development board" I connect the MPLAB ICD 2 and launch the PCW program select debug it starts down loading then I get the Error Code 85DE0016.
Clicking diagnostics does nothing and the debugger reports that the "MPLAB ICD 2" is not ready.. There is only a green POWER light on the MPLAB ICD 2
Any help would be appreciated I am using PCWHD v4.129
Code: | #include <24F16KA102.h>
#Device ICD=2
#device ADC=10
//#fuses debug
#FUSEs NOBSS //No boot segment
#FUSEs NOWRTB // NO Boot Block write protect
#FUSES NOCKSFSM // Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOBROWNOUT // No brownout reset
#FUSES NOWDT // No watch dog timer
#FUSES NOPROTECT // code is not protected from reading
#FUSES MCLR // Master Clear pin enabled
#FUSES NOPUT // No Power Up Timer
#FUSES NODSBOR // BOR disabled in Deep Sleep
#FUSES NOWRT // Program memory not write protected
#FUSES NOPROTECT // Code not protected from reading
#FUSES NODSWDT // Deep Sleep Watchdog Timer disabled
#FUSES NOIESO // Internal External Switch Over mode disabled
#FUSES FRC // Internal Fast RC Oscillator
#use delay(clock=8000000)
#include <new_test_004.h>
//#pragma use rs232(force_SW,invert, baud=115200, xmit=PIN_B0, rcv=PIN_B1, bits = 8, parity = N)
#use rs232(force_SW,invert, baud=115200, xmit=PIN_B0, rcv=PIN_B1, bits = 8, parity = N)
#define out15 PIN_B15 // the blinky bit
unsigned int16 value;
setup_adc_ports(sAN12);
setup_adc(ADC_CLOCK_internal); // Built-in A/D setup function
// TODO: USER CODE!!
value = 0;
set_adc_channel(12); // Built-in A/D setup function
value = read_adc(); // Built-in A/D read function
printf( "this is a test1 %u \n\r",value);
delay_ms(100); // Built-in delay function
output_low(out15); // this works
delay_ms(10);
output_high(out15);
delay_ms(10);
zagoaristides
Joined: 08 Jul 2007 Posts: 15 Location: Cordoba - Argentina
Re: MPLAB ICD 2 in debug mode |
Posted: Sun Nov 17, 2013 8:51 am |
jameszum wrote: | I am trying to use a MPLAB ICD 2 to debug code for a "24F16KA102" on a "16 bit XLP development board" I connect the MPLAB ICD 2 and launch the PCW program select debug it starts down loading then I get the Error Code 85DE0016.
#Device ICD=2
#device ADC=10
//#fuses debug
value = 0;
delay_ms(10);
output_high(out15);
delay_ms(10);
SAME ERROR!!! Any help? |
Posted: Sun Nov 17, 2013 11:35 am |
Your board uses the PGC/D3 pins not PGC/D2.
