MPLAB ICD 2 in debug mode
jameszum
PostPosted: Tue Jan 31, 2012 4:28 pm     Reply with quote
I am trying to use a MPLAB ICD 2 to debug code for a "24F16KA102" on a "16 bit XLP development board" I connect the MPLAB ICD 2 and launch the PCW program select debug it starts down loading then I get the Error Code 85DE0016.
Clicking diagnostics does nothing and the debugger reports that the "MPLAB ICD 2" is not ready.. There is only a green POWER light on the MPLAB ICD 2
Any help would be appreciated I am using PCWHD v4.129
#include <24F16KA102.h>
#Device ICD=2
#device ADC=10
//#fuses debug
#FUSEs NOBSS         //No boot segment
#FUSEs NOWRTB         // NO Boot Block write protect
#FUSES NOCKSFSM         // Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOBROWNOUT       // No brownout reset
#FUSES NOWDT         // No watch dog timer
#FUSES NOPROTECT      // code is not protected from reading
#FUSES MCLR            // Master Clear pin enabled
#FUSES NOPUT         // No Power Up Timer
#FUSES NODSBOR         // BOR disabled in Deep Sleep
#FUSES NOWRT         // Program memory not write protected
#FUSES NOPROTECT      // Code not protected from reading
#FUSES NODSWDT         // Deep Sleep Watchdog Timer disabled
#FUSES NOIESO           // Internal External Switch Over mode disabled
#FUSES FRC            // Internal Fast RC Oscillator
#use delay(clock=8000000)
#include <new_test_004.h>
//#pragma use rs232(force_SW,invert, baud=115200, xmit=PIN_B0, rcv=PIN_B1, bits = 8, parity = N)
#use rs232(force_SW,invert, baud=115200, xmit=PIN_B0, rcv=PIN_B1, bits = 8, parity = N)
#define out15       PIN_B15 // the blinky bit
   unsigned int16 value;
   setup_adc_ports(sAN12);
   setup_adc(ADC_CLOCK_internal);            // Built-in A/D setup function
   // TODO: USER CODE!!
        value = 0;
         set_adc_channel(12);                 // Built-in A/D setup function
        value = read_adc(); // Built-in A/D read function
          printf( "this is a test1 %u \n\r",value);
          delay_ms(100);                      // Built-in delay function
     output_low(out15); // this works
          delay_ms(10);
      output_high(out15);
          delay_ms(10);
zagoaristides
View user's profile Send private message Visit poster's website ICQ Number
Re: MPLAB ICD 2 in debug mode
PostPosted: Sun Nov 17, 2013 8:51 am     Reply with quote
#Device ICD=2
#device ADC=10
//#fuses debug
        value = 0;
          delay_ms(10);
      output_high(out15);
          delay_ms(10);
SAME ERROR!!! Any help?
PostPosted: Sun Nov 17, 2013 11:35 am     Reply with quote
Your board uses the PGC/D3 pins not PGC/D2.
